Next project: 1999 Pontiac Firebird 3.8L
Posted: Wed Jun 29, 2011 11:25 am
by bassplayaz06
So I've gotten my next project. it's my sister's 1999 Pontiac Firebird. The only bad thing is she's using my Vibe til I'm done with this...Has multiple problems needing to be fixed:misfire in #1 cylindersecurity issuedoor sensors causing alarm to go off when lockedbrakes: turned and bledweather strippingcleaned outspeakers
Re: Next project: 1999 Pontiac Firebird 3.8L (bassplayaz06)
Posted: Fri Jul 01, 2011 4:38 am
by bassplayaz06
Got the misfire fixed. had a random misfire in cyl. 6, turned out to be a bad plug wire and ignition module. replaced the ignition coil too for safe measure as i already had a new one.This is what i had to do to get to the dang plugs...
Posted: Fri Jul 01, 2011 10:47 pm
by TONY TAT2
Does it have the sensors in the T'tops also ?That could be the alarm problemIt should have sensors for the hatch & hood also
Re: Next project: 1999 Pontiac Firebird 3.8L (TONY TAT2)
Posted: Mon Jul 04, 2011 1:19 am
by bassplayaz06
I don't think it has sensors for the T-tops cause i can take them out and lock the car. the hood doesn't have a sensor, but the hatch does.
