'06 AWD ALB hub assembly
Posted: Mon Jun 27, 2011 8:15 am
by blankmonkey
I have a low pitch grinding noise from the back, after a 100$ inspection, a mechanic told me it was the LR hub assembly. They want 900$ to fix it. So I start looking around, but I can seem to find1) the haynes manual on an AWDor2) the part, that is not 370$ from the dealer.Also I see here there is some possibility that this may be the differential.Does anyone have some input here? someplace I may be able to get an hub assembly? Should I risk using a junkyard one?
Re: '06 AWD ALB hub assembly (blankmonkey)
Posted: Mon Jun 27, 2011 10:19 am
by sideshowalan
Attached is the service manual page on how to do this. Good gravy that looks complicated.Some people will knock ebay hubs, but they're inexpensive, new and depending on the seller usually carry a warranty. I replaced a hub on my wifes car last year with an ebay unit for 1/2 the price I was finding elsewhere, with zero problems so far.
Attached files 4wdhub.PDF (165.5 KB)
Re: '06 AWD ALB hub assembly (sideshowalan)
Posted: Mon Jun 27, 2011 10:20 am
by sideshowalan
Components list....
Attached files 4wdhubcomp.PDF (56.4 KB)
Posted: Mon Jun 27, 2011 10:21 pm
by Sublimewind
Quote, originally posted by sideshowalan »Attached is the service manual page on how to do this. Good gravy that looks complicated. Some people will knock ebay hubs, but they're inexpensive, new and depending on the seller usually carry a warranty. I replaced a hub on my wifes car last year with an ebay unit for 1/2 the price I was finding elsewhere, with zero problems so far. Complicated?? It's a simple bolt in part..??? The front has to be pressed out and back in and that's IF you can get the snap ring out...
Re: '06 AWD ALB hub assembly (Sublimewind)
Posted: Mon Jun 27, 2011 11:31 pm
by sideshowalan
Oh yeah it looked like the rear calls for a press too but I guess that's just for the dust shield. Bolt on is the way to go, they should have done that for the front too.
Posted: Tue Jun 28, 2011 2:32 am
by blankmonkey
I love you guys
Posted: Tue Jun 28, 2011 2:41 am
by blankmonkey
This doc referances section 32-41, 32-6, 27-32, 27-27, 27-7, and 05-316Do you have these possibly??
Re: (blankmonkey)
Posted: Tue Jun 28, 2011 3:01 am
by blankmonkey
I think I have actually found the whole manual, but I can seem to find anything in it, the whole structure is super vague with meaningless numbers. how did you find the right section???
