Does the Tensioner Belt/Pulley Need to be Replaced?
Posted: Tue Jun 21, 2011 2:35 am
by spuyear
Two separate mechanics suggested I replace the serpentine belt on my 2006 Vibe with 106K miles on it. I figured it was about time anyway. However, one of the mechanics also said that I needed to replace the tensioner belt or pulley.This seems like overkill to me but I am no mechanic (no even close). Do I need to replace the tensioner belt or pulley just because I need to replace the serpentine belt?Thanks!Shawn
Re: Does the Tensioner Belt/Pulley Need to be Replaced? (spuyear)
Posted: Tue Jun 21, 2011 2:44 am
by keithvibe
short answer no.long answer, depends on if you are seeing the belt "bounce" up and down while the car is running or hearing a "thumping" from the engine bay while you are driving. Or if the piston is leaking. Then yes it should be replaced
Re: Does the Tensioner Belt/Pulley Need to be Replaced? (keithvibe)
Posted: Wed Jun 22, 2011 12:39 pm
by spuyear
Thanks. I am having no issues with the Vibe. I think I'll just replace the serpentine belt.Shawn
