A/C Blower works eratically, in all speeds
Posted: Sat Jun 18, 2011 4:44 am
by nolaloha
The A/C Heater Blower is working unreliably. The blower usually will not start after the engine has been turned on. Trying all the blower speeds, vent open or shut, A/C on, heater on does not result in the blower working. Then usually,after a few minutes or hours, the blower will come on. Sometimes after a bump in the road, sometimes not. when it does come on, it works in all speeds, and can be turned off for a minute, and turned on again. The blower sounds smooth in all speeds, and once running, will keep running. Can you suggest some trouble shooting? Resistor? Fuse? Relay block? Blower motor?
Re: A/C Blower works eratically, in all speeds (nolaloha)
Posted: Sat Jun 18, 2011 6:22 am
by DressedInBlack
I im'ed you these but I will put them here for reference. http://forums.genvibe.com/zerothread?id=36099 http://forums.genvibe.com/zerothread?id=44248 Best of luck!
