2009 GT Monsoon ID3 and Radio Text no longer displaying
Posted: Mon May 30, 2011 10:53 am
by viewwin
Two days ago, the ID3 tags and radio text will no longer display on the main home screen on the factory radio. I can still bring it up with the display button, but info is no longer display while on the main screen. Has anyone else had this problem?
Re: 2009 GT Monsoon ID3 and Radio Text no longer displaying (viewwin)
Posted: Mon May 30, 2011 11:33 am
by 09vGT
Sometimes the autotext feature will turn itself off. I keep my off for this reason. But, click menu, then you should see autotext, click it, then click on. Or somewhere around the lines of that. You should be able to find it really easy.
Re: 2009 GT Monsoon ID3 and Radio Text no longer displaying (09vGT)
Posted: Tue May 31, 2011 2:12 am
by viewwin
Quote, originally posted by 09vGT »Sometimes the autotext feature will turn itself off. I keep my off for this reason. But, click menu, then you should see autotext, click it, then click on. Or somewhere around the lines of that. You should be able to find it really easy. I checked, the autotext is on. I turned it off then back on and still no text unless I press info
