'09 Vibe - Where to mount tweets?
Posted: Fri May 20, 2011 8:42 am
by TxVibe
I have non-premium 4 speaker stereo and wanted to get a component set. Any ideas on where to mount them? The side curtain airbags kinda mess with my original plan.
Posted: Fri May 20, 2011 8:49 am
by papacueball
The airbags are up higher than you would probably want to mount tweeters. Sail panels could be a good choice, too.
Re: (papacueball)
Posted: Fri May 20, 2011 12:13 pm
by TxVibe
Pardon my ignorance, but where exactly are "sail panels"? Got any pics?Papacueball, you seem to be on top of all my questions. Many thanks to you.
Posted: Fri May 20, 2011 8:42 pm
by papacueball
No problem, Tx. The sail panel basically covers the bolts and wiring for the side view mirrors. Should be plenty of room behind them, too.
Posted: Fri May 20, 2011 9:30 pm
by Sublimewind
I like tweeters in the kickpanels myself.. High in the kick, where the dash,door,kick all meet..
Re: (papacueball)
Posted: Sat May 21, 2011 1:07 am
by TxVibe
Quote, originally posted by papacueball »No problem, Tx. The sail panel basically covers the bolts and wiring for the side view mirrors. Should be plenty of room behind them, too.Oh cool, that's where I was hoping you were talking about. I think they would go good there.
Posted: Sat May 21, 2011 2:05 am
by ponta2147
Well, I know the tweeters in the Monsoon sound system are in that exact spot:
Re: (ponta2147)
Posted: Mon May 23, 2011 1:27 am
by bigdaddyjosh
Hey I have a non monsoon system and had my tweets installed professionally in the door. Here is where they did the install. Pay no attn. to the messy black surround. The installers did a crappy job and the speaker fell out several times. So I used some special glue that should keep that from happening again. I just need to cut off the excess.
Re: (ponta2147)
Posted: Mon May 23, 2011 2:31 am
by TxVibe
Quote, originally posted by ponta2147 »Well, I know the tweeters in the Monsoon sound system are in that exact spot:I wonder if I could put them in the door panels right below the sail panel.
Re: (bigdaddyjosh)
Posted: Mon May 23, 2011 2:33 am
by TxVibe
Quote, originally posted by bigdaddyjosh »Hey I have a non monsoon system and had my tweets installed professionally in the door. Here is where they did the install. Pay no attn. to the messy black surround. The installers did a crappy job and the speaker fell out several times. So I used some special glue that should keep that from happening again. I just need to cut off the excess.Don't relly want them that low in the door, but thanks for the suggestion.
Re: (TxVibe)
Posted: Mon May 23, 2011 4:46 am
by bigdaddyjosh
just fyi. Most auto sound manufacturers and installers recommend placing the tweeter and mid no more than a foot apart from each other due to some issue with timing. Sound travels at a certain speed and if the tweets are installed 2 feet from your ears and mids being 4-6 feet from your ears then the sound arrives at your ears at 2 different times.This may be very minute and un-hearable but this is just fyi.
Posted: Mon May 23, 2011 7:02 am
by Sublimewind
^^^ that's called phasing and it does pose a certain problem.. Thing is, most wouldn't even realize...
Posted: Tue May 24, 2011 12:35 am
by papacueball
Might be a good idea to get some adhesive backed velcro and try them in all the different locations. Once you cut a hole in the door panel, you're committed.
Re: (papacueball)
Posted: Tue May 24, 2011 12:51 am
by TxVibe
Now that's a great idea. I just might do that.
Re: (TxVibe)
Posted: Tue May 24, 2011 1:10 am
by bigdaddyjosh
How big are your tweets? Mine are 1" and with the cups they sit in 1.5"the installer down here recommended not putting them in the sail panel because the panels have a slight curve in them and he wouldnt be able to make them sit flush. It could be done, I think... But you would have to figure out a better way to mount without the cups.Im truly interested to see how it all comes out.
Re: (bigdaddyjosh)
Posted: Tue May 24, 2011 1:32 am
by TxVibe
This is where (in white circle) I really want to put them, mounted flush. Haven't checked if there's room to do it or not though.
Posted: Tue May 24, 2011 3:50 am
by Sublimewind
Do they have a surface mount? Most have some sort of a slightly aim-able rotating cup to surface mount.. rather than flush mount..
Re: (Sublimewind)
Posted: Tue May 24, 2011 4:02 am
by TxVibe
Quote, originally posted by Sublimewind »Do they have a surface mount? Most have some sort of a slightly aim-able rotating cup to surface mount.. rather than flush mount.. Haven't bought any yet, but my goal is flush mount. May not be possible but will try that avenue first. Even if it means buying them separately.
