WILL THESE RIMS FIT MY 2003 PONTIAC VIBE
Posted: Tue May 17, 2011 4:40 pm
by KINGCOLIN420
hi i was wondering if these rims i saw on Kijiji would fit on my 2003 Pontiac vibe. they are 17inch rims dont know about the bolt pattern. any input would be great. thanks.
http://img1.classistatic.com/c....jpegh ... /c....jpeg
Re: WILL THESE RIMS FIT MY 2003 PONTIAC VIBE (KINGCOLIN420)
Posted: Tue May 17, 2011 6:44 pm
by moonstonemike
No those wont fit, they are for a 4 bolt but with two sizes drilled in. You need a 5 bolt by 100mm 5X100
Re: WILL THESE RIMS FIT MY 2003 PONTIAC VIBE (moonstonemike)
Posted: Wed May 18, 2011 10:47 am
by MotoAce51
Quote, originally posted by moonstonemike »No those wont fit, they are for a 4 bolt but with two sizes drilled in. You need a 5 bolt by 100mm 5X100^What they said. And it looks like he has the same wheels in grey.
Posted: Wed May 18, 2011 10:56 am
by lovemyraffe
I agree with the other two. Need a 5x100.
Posted: Wed May 18, 2011 11:33 am
by KINGCOLIN420
K thanks guys, so any input on if these rims will fit, guy said he took them off a pontiac, not sure what make though. there 16inchhttp://img1.classistatic.com/c....jpeg
Posted: Wed May 18, 2011 11:45 am
by KITT222
Those look like they're off a Bonneville, and the Bonnie has a 5-114 bolt pattern, so unfortunately, no. Most Toyota rims as well as Scion rims will fit, though. Many on the board here have OEC TC rims on their Vibes, and they look good. EDIT: Lovemyraffe has TC rims on his Vibe, in his sig.
Posted: Wed May 18, 2011 11:54 am
by KINGCOLIN420
thanks alot i must be gettin annoying haha.any idea if these will fit, five bolt but there 18inch.
Posted: Wed May 18, 2011 11:58 am
by KITT222
Oh not at all... Ask the seller for the bolt pattern. The Vibe's is 5x100. If it is 5x100, than it will work. 5x114, no. That will not work.
Posted: Wed May 18, 2011 12:00 pm
by KINGCOLIN420
k thanks alot, these have a 5bolt gm pattern there 17inch and came off an aztec.any chance of them fitting?
Posted: Wed May 18, 2011 12:11 pm
by KITT222
Nope. From Pontiac, Grand Am and Sunfire rims will work. No other rims form Pontiac will work.
Posted: Wed May 18, 2011 12:16 pm
by KINGCOLIN420
k great thanks, so will any 5 x 100 bolt rims fit.
Re: (KINGCOLIN420)
Posted: Wed May 18, 2011 12:20 pm
by KITT222
Yes, ANY 5x100 bolt pattern rims will work.
Re: (KITT222)
Posted: Wed May 18, 2011 12:23 pm
by KINGCOLIN420
k awesome so these rims should fit for sure.there 18inch 5x100/5x114.3http://toronto.kijiji.ca/c-car...43451
Re: (KINGCOLIN420)
Posted: Wed May 18, 2011 12:29 pm
by KITT222
Yep, those'll work!
Re: (KITT222)
Posted: Wed May 18, 2011 12:58 pm
by KINGCOLIN420
awesome thanks alot.so these ones should be good as well im assuminghttp://toronto.kijiji.ca/c-car...03349
Re: (KINGCOLIN420)
Posted: Wed May 18, 2011 5:34 pm
by Vinlandr
Bolt pattern is not the only important thing.Offset too, as a wheel can endup too far inside the wheel well or to much outside. Here is a chart
http://forums.genvibe.com/zerothread?id=41523Center bore of the wheel too, on Vibe its 54.1mm anything smaller will not even fit and bigger might require a center ring to prevent vibration.
Posted: Wed May 18, 2011 7:21 pm
by MotoAce51
Probibly should also mention tire size could kick your spedo off too. You need a different profile to in the end the OD is still the same as before.
