i have a 2003 base model vibe and i hate my lights i want to get HIDS can i do that without projectors or do i need to fit projectors on my car and if so can i do that myself on do i have to send them to someone if i can do it myself is it had and are there instructions to do it
Welcome,You can certainly can do a set of plug and play H4 HID's for the vibe. Lots of others have gone this route with out issue.If you want to take pitty on the people you would be blinding you can get a retrofit done.You can buy a DIY kit if you are comfortable about putting your headlight into your oven to bake it open.I do offer a service to retrofit projectors in to supplied headlights. If time is an issue you can buy a set of junkers, to get retrofitted or use the junkers while your current headlights are being retrofitted.I do have a set of 03-04 headlights that are in need of TLC but can be retrofitted.If you wanted to go that route you can contact me or had more questions at: sales (@) ultimateretrofit.com
