Rear Liftgate replaced, lock does not work
Posted: Sun May 08, 2011 8:30 am
by phred923
We recently had the rear lift gate replaced on our 03 Vibe after a little fender bender, not the lock will not work and the hatch release either. I Knew the key would not work since was a replacement ,but was wondering if it was possible to somehow program the key bobs to work on the new lift gate &/hatch glass. Will call the body shop tomorrow as well, but thought the good folks on the forum may have some thoughts. Thank You.
Re: Rear Liftgate replaced, lock does not work (phred923)
Posted: Sun May 08, 2011 11:40 am
by petervivian
They should remove your old lock and put it into the new lifegate. And you don't have to program anything to let the liftgate lock and hatch release to work. Most likely the wires of the new gate are not correctly connected.
Posted: Sun May 08, 2011 12:14 pm
by star_deceiver
Take it back and have them fix it properly!Welcome to GenVibe BTW!!!
Re: Rear Liftgate replaced, lock does not work (star_deceiver)
Posted: Mon May 09, 2011 1:48 am
by phred923
Thanks, bringing it back in to get checked out, Seemed logical to me that they would have minimally switched the locks out when doing the replacement, so I never even thought to check. The repairs were completed 2 weeks ago so not likely they have the old one around:
Posted: Mon May 09, 2011 2:11 am
by djkeev
Quote, originally posted by phred923 »Thanks, bringing it back in to get checked out, Seemed logical to me that they would have minimally switched the locks out when doing the replacement, so I never even thought to check. The repairs were completed 2 weeks ago so not likely they have the old one around: Then they owe you a rekey fee to make the "new" lock work with your original key along with any labor charges incurred to remove and reinstall the lock for the rekey process.I HATE repair shops that do crap work and charge premium money!!!!Dave
Re: Rear Liftgate replaced, lock does not work (djkeev)
Posted: Sun May 15, 2011 8:52 am
by phred923
turns out the actuator on the new lift gate was not working correctly, so the key ob did not work. Lock was my fault for trusting my daughter, it worked fine when I tried it .
