Custom Air Intake???
Posted: Tue May 03, 2011 7:08 am
by christo
Hi,I searched on the forum, read a lot and, the conclusion : the only after market air intake for the 05' Vibe is the COSMO RACING one...So, I want to make my own Custom SRI...For that, I need the dimensions to install the MAF on the tubing...But, if you tell me that Some MATRIX Air intake will fit my VIBE w/ only few modifications, I'll be interested!If you ever try to make your own, you can put picture here...When my design will be final, I will show you!Thank you!
Re: Custom Air Intake??? (christo)
Posted: Tue May 03, 2011 9:06 am
by bassplayaz06
here's what i did... it's the top of the air box, flipped upside down to fit the filter.
Posted: Tue May 03, 2011 9:18 am
by Salsa Guy
The intakes are the same between a Matrix-Vibe. The same engine and throttle body. You need to consider the year and engine type (1zz or 2zz).
Re: Custom Air Intake??? (rmckinjr)
Posted: Tue May 03, 2011 9:51 am
by christo
I got a '05 Vibe Base, with electric throttleBut I'm not sure that all Matrix/Vibe are the same....
Posted: Tue May 03, 2011 10:04 am
by Salsa Guy
Vibe = Matrix as far as engine and intake!
Posted: Tue May 03, 2011 10:07 am
by Salsa Guy
So whats wrong with the Cosmo?
Re: (rmckinjr)
Posted: Tue May 03, 2011 10:09 am
by christo
Nothing, but I don't want to pay as much if I can get the same result by using ebay parts!
Re: (christo)
Posted: Tue May 03, 2011 10:47 am
by bassplayaz06
$150 for a CAI, $115 or so for a SRI, it's worth it to just buy one than make one and mess up the systems.
Posted: Tue May 03, 2011 11:15 am
by Salsa Guy
^X2 Go buy an ebay intake. The main concern is the MAF seal. If you get that the nyou shouldn't have a problem. Or you can add a KN filter and call it a day (it's about $50). Then there is the dryer hose mod.....
Re: (rmckinjr)
Posted: Tue May 03, 2011 11:47 am
by christo
But what about the the throttle body diameter???? I want te be sure that it will fit before ordering!
Re: (rmckinjr)
Posted: Wed May 04, 2011 6:52 am
by MotoAce51
Quote, originally posted by rmckinjr »^X2 Go buy an ebay intake. The main concern is the MAF seal. If you get that the nyou shouldn't have a problem. Or you can add a KN filter and call it a day (it's about $50). Then there is the dryer hose mod.....Whats a dryer hose mod?
Re: (MotoAce51)
Posted: Wed May 04, 2011 8:18 am
by Salsa Guy
Quote, originally posted by MotoAce51 »Whats a dryer hose mod?You REALLY want to know. It's also called a poorman/redneck/hillbilly CAI. Basicly you fine some flexible metal duct that will fit the Throttle Body to Stock air box. Then will from Stock Air box to behind the fender. You need to add a high flow filter for any results. But by the time you do all that with all the cost you maybe $40 away from a Cosmo CAI
Re: (rmckinjr)
Posted: Wed May 04, 2011 8:54 am
by bassplayaz06
yeah, that cosmo CAI don't like to fit much... expecially when they send you the wrong one.
Posted: Wed May 04, 2011 8:55 am
by christo
Ok guys... I will explain my mind...I really want a SRI... but I searched on the forum... and results that there is only 1 SRI that can be installed on the 05' Vibe : the COSMO...I want to know if I'm right or wrong...If I can purchase a matrix SRI on ebay (sorry guys but I plan to go back University next fall)So : is the COSMO RACING SRI the only one for my Vibe???
Posted: Wed May 04, 2011 9:24 am
by Salsa Guy
Cosmo is the cheapest! The only problem you may run into is where the breather port to the valve cover is located. Is it connected to the Throttle body or connected to the intake hose (just before the throttle body). If it's connected to the TB your OK. If it's connected to the Intake hose you'll need to put a $10 breather filter on it and call it good.
Re: (rmckinjr)
Posted: Wed May 04, 2011 9:35 am
by christo
So, I can buy a cheap SRI on ebay for Matrix XR? And it will work fine and be easy to install on my Vibe???
Re: (christo)
Posted: Wed May 04, 2011 10:05 am
by MotoAce51
Quote, originally posted by christo »So, I can buy a cheap SRI on ebay for Matrix XR? And it will work fine and be easy to install on my Vibe???yes.. But you will see more results with the CAI... For the price difference, Id go with the CAI....
Re: (MotoAce51)
Posted: Wed May 04, 2011 10:11 am
by christo
As I read, with a SRI, you increase the MPG... And reguarding our climate, I prefer the SRI
Re: (MotoAce51)
Posted: Wed May 04, 2011 10:19 am
by Salsa Guy
Oh no not another CAI vs SRi debate. The SRi is easier to install and maintain.
Re: (rmckinjr)
Posted: Wed May 04, 2011 7:23 pm
by MotoAce51
Quote, originally posted by rmckinjr »Oh no not another CAI vs SRi debate. The SRi is easier to install and maintain. ^ Can't argue that at all. Sometimes I wish I had the SRI because of that part.
