40k with two bad axles
Posted: Sun Apr 17, 2011 7:54 pm
by keithvibe
Yup, was doing some work to the vibe over the weekend and found that both CV joints (rubber boots) on the front axles are leaking. I'm disappointed to say the least.... I'm going to do some creative work to the axles to prolong the work for the time being.Time to start shopping for axles. I've changed axles on a Matrix and (removed) it was a PITA. Not sure I want to tackle it again.
Posted: Sun Apr 17, 2011 9:34 pm
by Salsa Guy
That sucks! I guess you can't just replace the boots. But if your going in there to replace them you might as well change out the joints and etc.
Re: (rmckinjr)
Posted: Sun Apr 17, 2011 9:48 pm
by keithvibe
I could just change the boots but I would rather have a factory seal. Then again the factory seal is what is leaking lol
Posted: Sun Apr 17, 2011 9:59 pm
by Salsa Guy
Some times aftermarket is better!
Re: 40k with two bad axles (keithvibe)
Posted: Sun Apr 17, 2011 10:03 pm
by BlueCrush
Excellent! something to look forward to after I replace the rear differential output shaft seals.
Re: 40k with two bad axles (BlueCrush)
Posted: Sun Apr 17, 2011 11:21 pm
by keithvibe
The boots are not torn just leaking around where the boot meets the axle shaft. My plan is to clean it up and add a bead of silicone Or black rtv sealant around the end of the boot to help reduce the leaking till I can buy two new axles
Posted: Sun Apr 17, 2011 11:44 pm
by bassplayaz06
it wasn't that hard to take them out on my vibe when i changed the clutch. just take the wheel hub's off and they pull right out.
Re: 40k with two bad axles (bassplayaz06)
Posted: Mon Apr 18, 2011 12:51 am
by keithvibe
Odd cuz the xrs that I changed them on were spring clipped inside the trans. Had to pry them out. Also the awd axles are diff than the 2wd ones dont know what they will be like
Posted: Mon Apr 18, 2011 9:56 am
by lovemyraffe
Sounds like lots of fun. They are a PITA. HUGE PITA. Kinda weird that they are dead at 40k.
Posted: Mon Apr 18, 2011 1:01 pm
by j42.snyder
Sounds to me like they just need new clamps at the inboard ends. Unless they've leaked a lot, chances are everything's still fine inside.I had a couple like that on a 1987 Buick. I think that was 10 years ago or so that I noticed it. My neighbor is still driving the car daily - never needed to change the axles.They sell specific clamps for those, and you could probably rent/borrow the tool, or buy it fairly cheaply. If the "leakage" is only very slight, and the boots still feel fairly well clamped to the axle, then it may not be worth worrying about. If you're not sure - I'd get a second opinion from someone you trust. I wouldn't write off an axle from a little grease seepage there...John
Re: (j42.snyder)
Posted: Mon Apr 18, 2011 9:03 pm
by keithvibe
Thanks John I'll look around
Posted: Tue Apr 19, 2011 3:20 pm
by ou.grizzly
Aren't you both lowered?
Re: (ou.grizzly)
Posted: Tue Apr 19, 2011 11:34 pm
by keithvibe
Havent been lowerd now for over a year
