electrochromatic compass mirror for 2004 vibe?
Posted: Sun Jun 29, 2003 9:20 am
by korgull
Hi All,Has anybody got an electrochromatic compass/temperature mirror for the vibe? With the map lights on the stock mirror, I was just wondering if there was a special one available for the vibe? I havent checked the dealer yet as they are always more expensive. Are there any aftermarket ones available? If the dealer is the only way to go, might one of you have a picture?thanks
Re: electrochromatic compass mirror for 2004 vibe? (korgull)
Posted: Sun Jun 29, 2003 12:11 pm
by Herb
We discussed this a few months ago. There's one available apparently for the Matrixhttp://forums.genvibe.com/zerothread?id=3723&postid=38807#38807
Re: electrochromatic compass mirror for 2004 vibe? (Herb)
Posted: Mon Jun 30, 2003 8:20 am
by VibeForWinter
I just installed one in my car last week. I bought the one for a Mazda 6, it uses the same mount. It doesn't have the map lights. Install was a snap.http://www.mazdastuff.com/product.cfm?ProductID=1297
Re: electrochromatic compass mirror for 2004 vibe? (VibeForWinter)
Posted: Mon Jun 30, 2003 9:21 am
by korgull
Nice! $119 versus $268 from Toyota is a sure sale for me.. the compass could be a little bigger though.. then again, I think Ill take it for the over $100 savings. Plus, there already is a temperature guage in the Vibe, so I wouldnt need the temp on the mirror.thanks!If anybody else has a comparable mirror, please post it here!
Posted: Mon Jun 30, 2003 11:31 am
by AKLGT
wow! look at all those nice parts for the Mazda 6. Sure would be nice if we had more OEM quality parts.I had the auto dimming mirror in my Tundra with compass/temp and map lights. It was pretty nice and saved me from a lot of bright headlights in my eyes. I highly recommend them.
Posted: Mon Jun 30, 2003 9:06 pm
by Pawel
Excellent idea!!!!!!!
Posted: Wed Jul 02, 2003 8:29 am
by ColonelPanic
quote:I just installed one in my car last week. I bought the one for a Mazda 6, it uses the same mount. It doesn't have the map lights. Install was a snap.Nice! How about wiring? I'm assuming just a switched 12V and GND would be all that is necessary? Where did you get the power from? I'm thinking the 12V to the moonroof controls would work...I definitely want to look into this... Thanks for the info!
Re: electrochromatic compass mirror for 2004 vibe? (ColonelPanic)
Posted: Wed Jul 02, 2003 8:56 am
by VibeForWinter
Yep, switched power and ground are all you need. I had previously spliced into the cigarette lighter plug power lead when I wired up my radar detector, so I used this same power source for the mirror. I ran the mirror wiring up the pass. side A pillar and under the front edge of the headliner over to the mirror. The moonroff power would probably work well also, you will need to shorten the wires that come with the mirror so you are not trying to stuff 4 feet or so of wire up under the headliner.The front edge of the headliner can be dropped a bit by removing the sunvisors, then twisting the inner sunvisor retaining clips 90 degrees.
Re: electrochromatic compass mirror for 2004 vibe? (silverawd26)
Posted: Wed Jul 02, 2003 9:37 pm
by esjones
quote:Might be something I will get. A compass would really help out when driving on trips. I thought about this, too. My 88 Bonneville had a compass in it, and I liked that a lot. Then, it hit me... I HAVE THE NAV SYSTEM, and THAT has a compass already in it. DUHHHH!
Posted: Fri Jul 04, 2003 1:15 pm
by ColonelPanic
Great tips there! So, the mirror comes with the necessary wiring? Since that's the case, I may just tap into somewhere underneath - power outlet, etc.I may just order me one... Thanks!
Posted: Fri Jul 04, 2003 1:48 pm
by Geo
Whatever happened to just looking at the sun and knowing what direction you are heading, not to mention what time it is?
Posted: Wed Jul 09, 2003 9:25 am
by korgull
quote:I just installed one in my car last week. I bought the one for a Mazda 6, it uses the same mount. It doesn't have the map lights. Install was a snap.http://www.mazdastuff.com/product.cfm?ProductID=1297Are you saying that the Mazda 6 mirror has the same exact mount? Or does it just need a simple adapter. Havent got my Vibe yet(probably another month . Is the mirror mount a clip or a cam?thanks
Posted: Fri Jul 11, 2003 10:22 am
by VibeForWinter
The Mazda 6 uses the same mounting button on the windshield. The Vibe mirror is secured with a screw. Tha Mazda mirror uses a clip (basically, a spring tab that puts pressure against the button as you slide the mirror on). No adapters needed, simply remove the screw from the stock mirror, slide it off, and slide the new one on, and you're done
