final audio system in the vibe
Posted: Thu Mar 31, 2011 2:41 pm
by vibe11
just got an old school exodus audio tempest x1 15 inch and an old school farenheit class x 620-2. the sub is dual 8ohms and is 1000rms and 2000max. the amp is 600rms at 4ohms and 1200max at 2ohms i will be running the sub at 4ohms. the box will be ported with 6 cubic feet of air tuned at 30hertz.
Re: final audio system in the vibe (vibe11)
Posted: Fri Apr 01, 2011 11:26 am
by Blanco_Diablo
Can't wait to see it all installed!
Posted: Fri Apr 01, 2011 1:57 pm
by Sublimewind
you realize 6cf is basically your whole trunk right?...lol..
Re: (Sublimewind)
Posted: Sat Apr 02, 2011 9:38 am
by vibe11
yeah. i never use the trunk. its only in use when i have subs. this is my last set up in the car, im gonna all out with the box. box will be finished tuesday.what u guys think on color?black vinylgray vinylblack carpetgray carpetor just plain mdf
Posted: Sat Apr 02, 2011 11:39 pm
by Sublimewind
You don't have NEARLY enough amp for that sub @4ohm... Being that's a D8 sub, you have 16 or 4 ohm opp options... that amp is 600w @4ohm... you're going to cook the sub.. Especially in ported.. If you hit below the port tuning freq and unload the box, it wouldn't take much.. Will be an interesting build though I suppose, I mean bass is just that, bass... covers the narrowest band of frequencies reproduced.. I think you should leave it bare MDF for that TRUE B-b-b-bass head look... lol..
Re: (Sublimewind)
Posted: Mon Apr 04, 2011 2:51 am
by vibe11
there is plenty enough amp for that sub, im posting pics later on the build. that amp is both a high current amp and efficient on power, hence the class x. by far the cleanest and loudest setup ive had in the vibe
Re: (vibe11)
Posted: Mon Apr 04, 2011 2:57 am
by vibe11
the sub calls for a ported box between 4.5 and 6cu ft and a sealed between 7 to 12 cu ft. im going to leave it bare lol
Re: (vibe11)
Posted: Thu Apr 07, 2011 2:06 pm
by Sublimewind
Quote, originally posted by vibe11 »there is plenty enough amp for that sub, im posting pics later on the build. that amp is both a high current amp and efficient on power, hence the class x. by far the cleanest and loudest setup ive had in the vibeWell man, I don't want to be the bearer of bad news, but your amp isn't what you think... I'm just trying to save you a sub.. totally not trying to be a jerk... Lemme show you.. Ohm Laws says that Power(w) =E(volts) x I(amps)Consider 12v and I see either 2 yellow (2x20a) or 2 clear (2x25a) fuses in your amp.. 12x40=480w12x50=600wIF you get 14v consistently (which you might but not likely) you can14x40=560w14x50=700wThese values are AT fuse rating, which is the point in which the fuse blows, so the amp actually runs below that... So I am sorry to say, might not be the power you think... AFA it being a "high current" amp, high current operation only takes place at lower ohm loads, at best you can achieve a 4ohm static load on the amp... High current is considered 2 to 1ohm and below... AFA "class x" that's simply a branding that that amp company used, there is no current "class x" topology being used in the amplifier industry (nor has there been any) If it's old school as you say, it's likely a class A/B like everything else, but could be a class D... So again, I am sorry to be the bearer of bad news, I fear for your sub.. Edit: did a little more digging, google is a great thing... found this.. http://www.farenheitusa.com/PD...a.pdfSeems that amps is rated for 155x2@4ohm, 250x2@2ohm and 500x1@4ohm (not rated for 2ohm mono)Again, I'm just trying to save that sub man, it looks like it could soak up a LOT more power and be happy (too much power is just enough in your case, trust me, I stayed at some shady hotel last night)
Posted: Thu Apr 07, 2011 2:27 pm
by Sublimewind
I ran a pair of JL 12w0 (Old) which were rated @125wrms, on 250wrms for 3-4 YEARS of flogging, before a voice coil separated from the cone of one.. If you don't have 1000wrms or MORE to throw at that sub, I wouldn't even start.. jus sayin.. I'm not a SPL guy, but I know my car audio, you simply don't have enough power and well, it's up to you... Have you modeled it out on WinISD at all? (great program)
Re: (Sublimewind)
Posted: Fri Apr 08, 2011 7:50 am
by vibe11
im not going to argue about this , the amp has enough power, i have been installing and repairing amps for many years. if mu lived in Columbus u could come check it out. i called farenheit and they explained about the amp., first of all jl subs sound good but the tinsle leads are too short, and the surround dry rots on all there old subs. ive had all there subs
Re: (vibe11)
Posted: Mon Apr 11, 2011 4:53 am
by vibe11
new pics
Posted: Wed Apr 13, 2011 10:28 am
by MotoAce51
Looks good. I would have put the vent forward though. How's it sound?
Posted: Wed Apr 13, 2011 11:18 am
by audiovibe
Thats a mighty big box! What did you tune it to? Edit: I placed a thumbs-down by accident was supposed to be a thumbs-up, my mistake.
Posted: Sun Apr 17, 2011 3:21 am
by vibe11
it sounds amazing. its tuned to 30.12 hertz
