Timing chain tensioner and ticking noise
Posted: Sat Mar 26, 2011 12:46 pm
by wallyuwl
We all know the 1ZZ engine makes a ticking noise. It seems to have gotten worse as the car has gotten more miles on it. Does anyone know if replacing the timing chain tensioner (not the serp belt tensioner) might help with this? Or is changing the VVTi filter the main thing to do to help this? I do plan on changing this filter in a couple weeks.
Posted: Fri Jan 20, 2012 12:28 am
by leemur
my 04 has started rattling on cold start accelerations. More like octane pinging but dull like rattling instead of pinging high pitched.Never did it til this winter. clues? I thought VTi filter also because low rpm accelerations have a dull sound now like it's bogged down.
Posted: Mon Jan 30, 2012 2:34 am
by sideshowalan
Have you ruled out the serpentine belt tensioner? Good way to diagnose is to run the engine with and without the belt. The noise should go away without the belt if it's the serpentine tensioner. Of course don't run it too long without, the oil and water pumps will not turn.Or do a visual inspection, the oil leaks out of the tensioner piston and leaves a thick reside around it.The timing chain tensioner shouldn't need changing unless it's leaking.
Re: (leemur)
Posted: Mon Jan 30, 2012 4:26 am
by b03matrix
For timing chain tensioner: http://www.paulstravelpictures....html
