starter not disengaging
Posted: Sat Mar 26, 2011 5:20 am
by chevelle_lover
Today after I start the car for about 5 seconds there is a grinding noise coming from the engine bay. The sound is present then just suddenly stops. The noise does sound like it is coming from the back of the motor towards the fire wall. I checked the upper bearings with a stethoscope and nothing unusual. I was wondering if anyone else has had this issue. I need to put the car on ramps to check to see if the noise is coming from the starter or not. I put it on ramps and continued to diagnose the issue. Fortunately it started to do it all the time so it is not the starter but the A/C compressor clutch. So for now I will be driving with the A/C on until I get the part.
Re: starter not disengaging (chevelle_lover)
Posted: Sat Mar 26, 2011 10:05 pm
good job locating the source of the sound.
Re: starter not disengaging (joatmon)
Posted: Sun Mar 27, 2011 11:53 am
by cq358
do you think is a belt issue?
Posted: Mon Mar 28, 2011 9:15 am
by chevelle_lover
No I do not think it is a belt issue as soon as I hit the on button on the dash for the A/C the noise goes away. I will be changing the belt anyway.
Posted: Wed Mar 30, 2011 11:48 pm
by chevelle_lover
damn it I found the part, bought the tools and now it is not making any noise. My buddy who is a GM tech said sometimes rock or road salt will get in make noise for a couple days then get ground out so no more noise. I will still take the parts but I will not worry unless it starts up again.
