Starts rough.
Posted: Fri Mar 25, 2011 6:34 am
by DopeVibeGT
The last couple of days, I've starts my Vibe and when it starts, the rpm's drop for a second, like it's going to stall, then go back up. Before, it just started and went right up to idle. Only thing I've had done recently was the serp. belt (Which was a nightmare!!! Who designed those tensioners??) Any ideas.
Posted: Fri Mar 25, 2011 9:15 am
by Sublimewind
how's the battery? Idle air control valve controls idle, so it's possible it's on the fritz or dirty.. Tune up?
Re: (Sublimewind)
Posted: Fri Mar 25, 2011 9:23 pm
by DopeVibeGT
Battery is around a year old.I can check the IAC valve. Would that effect the idle all the time, even when warm?Plugs have less then 50K miles on them. Maybe I'll just replace them, though....Edit: Where is the IAC on the GT?
