NEEDED to know
Posted: Tue Mar 22, 2011 10:36 am
I tried the tensioner replacement but could not get the engine to move up high enough to clear the bolt...I removed the center bolt off the mount I found located behind the radiator. Where are the mounts I should have done? ALSO I saw footage of someone with tire chains on a Vibe...WHERE DID YOU GET THEM ,.....our car is horrid in tall snowyou can yahoo me the info same name on herte but add the yahoo.com
