Help with coolant leak in a 2000 Camry
Posted: Sun Mar 20, 2011 11:33 pm
by lovemyraffe
My wife's 2000 Camry, 2.2L 4 cyl, is experiencing a major coolant leak. I've already checked the radiator reservoirs and replaced the thermostat and it is still leaking. Anyone have other suggestions?
Re: Help with coolant leak in a 2000 Camry (lovemyraffe)
Posted: Mon Mar 21, 2011 5:02 am
by 808 Vibes
Oh no...pressure test system and cap? Better yet, leave it there and buy another Vibe You could name it "Taxes". You would have "Death" and "Taxes"
Posted: Mon Mar 21, 2011 6:17 am
by keithvibe
As HPL suggested, have the system pressure checked. They will remove the rad cap put on another cap that alows them to pressurize the system to find the leak.Or you can buy your own and DIYhttp://
www.amazon.com/Stant-12...SRGWUThat was just one a a few from a quick google search.Tough to pinpoint, and guessing is just that guessing.Could be something as simple as a lose hose, to something major as a waterpump or head gasket.Are you noticing a low level in just the overflow tank? or in the rad as well?No puddles?
Re: Help with coolant leak in a 2000 Camry (keithvibe)
Posted: Mon Mar 21, 2011 6:37 am
by lovemyraffe
The head gasket is fine. Signs are leading to the water pump. Here's to the water pump!
Re: Help with coolant leak in a 2000 Camry (ndrewoods)
Posted: Wed Mar 30, 2011 10:54 am
by lovemyraffe
I changed the water pump and haven't had a problem since.
