2005 Vibe - recall for PCM done CEL still on
Posted: Wed Mar 09, 2011 10:51 pm
by rustysteel
Hello,I have had an on going problem with our '05 Pontiac Vibe for over 2 years now. I've replaced both 02 sensors, plugs, kept oil changes and other maintenance has been taken car of. Just had the PCM replaced due to recall and I thought that would clear the CEL but it is still on. Any other ideas, I haven't checked the lasted code.thanksGlenn
Re: 2005 Vibe - recall for PCM done CEL still on (rustysteel)
Posted: Thu Mar 10, 2011 12:18 am
by ehoff121
What codes are you getting?
Posted: Thu Mar 10, 2011 1:25 am
by keithvibe
Quote, originally posted by rustysteel » I haven't checked the lasted code.Quote, originally posted by ehoff121 »What codes are you getting?^^this, without knowing what the code is you will be guessing, at best... nobody could give you a clue what the issue is till the code(s) is/are posted.
Re: 2005 Vibe - recall for PCM done CEL still on (keithvibe)
Posted: Thu Mar 10, 2011 1:52 am
by rustysteel
I will get the codes, just wondered if anyone had a similar issue before/after recall. Last one I had was for the primary 02 sensor. This continued even after the 02 sensors (secondary and primary) were changed. I thought the PCM was the culprit but even when I disconnect the battery and clear the CEL, it comes back on with a minute.I'll borrow a code reader and get back to you. thanks.
Posted: Tue Mar 15, 2011 11:44 pm
by rustysteel
Just got back from the dealer, Code 0031 is coming up. Cleared the codes and the CEL came back on within 60 seconds. Any ideas?thanksGlenn
Posted: Wed Mar 16, 2011 12:05 am
by Salsa Guy
That's an OPEN cicuit on the heater for the front O2 sensor (located on the exhaust mainfold). Was the new O2 sensor an OEM or aftermarket? If aftermarket was it a direct fit or did you need to splice wires for it? I'd check the wiring and connectors for it and make sure it all looks good. If so you may be able to check the resistance accross the hearter to make sure it isn't open. The hearters in this thing are nothing more than a resistor. Goodluck!
Posted: Wed Mar 16, 2011 3:44 am
by Salsa Guy
The resistance across the O2 heater should be 5 - 14 ohms
Re: (rmckinjr)
Posted: Wed Mar 16, 2011 10:30 am
by rustysteel
thanks, I'm going to check it tomorrow and see what the reading are.
