led replacement lights
Posted: Wed Feb 23, 2011 5:57 am
by wizardai
Have any of you bought/installed the led replacement lights for dome/map or other lights?Here's an example of what I'm talking about:
http://cgi.ebay.com/ebaymotors...oriesOn another note, our 2005 base vibe has map lights attached to the rear view mirror. Could someone provide what type of bulb that is? I can't seem to find it anywhere. Any thoughts on these LED replacements?
Re: led replacement lights (wizardai)
Posted: Wed Feb 23, 2011 6:20 am
by KITT222
Not those ones, but I did buy something similar. Three flat SMD boards with a small harness, and three different connectors each. But those look like they'll work with the mid and rear lights. I LOVE my new LED interior lights. They are so bright, I can see every corner of the interior with them. I highly recommend them to anyone and everyone.
Posted: Wed Feb 23, 2011 9:10 pm
by Wolfman213
I think I have only 2 bulbs that have not been switched over to leds yet and those are the outlet indicator and the... hmm... not sure. I can't remember what bulb type it is. Check under the interior bulb list thread and it is probably listed there. If not check sylvania or simply measure it.
Oznium
Posted: Wed Feb 23, 2011 10:21 pm
by DressedInBlack
i went here and found four different options.i wound up buying these (16 LED) and couldn't be happier. they are very bright. a little pricey but it is just what i was looking for. there might be a cheaper alternative out there somewhere though...
Posted: Thu Feb 24, 2011 2:10 am
by Wolfman213
Same ones I got! Well I think I done the 25 though, not sure. I remember measuring them and you could barely squeeze two of the boards in there, can't remember the size though. Mine are blue and I have them in the dome and hatch. Flood the Vibe with plenty of light. The blue makes some things difficult to see though, but still worth it!!
Posted: Thu Feb 24, 2011 9:24 pm
by joshuaeb09
I replaced all mine with LED's but I didn't buy anything premade I put it all together my self. 16 LEDS on each side in the front map lights then 8 in each dome light in the back. How ever i did put one of the 4led x 4 led grids in my grandfathers truck and they were pretty bright.
Re: (joshuaeb09)
Posted: Fri Feb 25, 2011 5:07 am
by Water boy
Quote, originally posted by joshuaeb09 »I replaced all mine with LED's but I didn't buy anything premade I put it all together my self. 16 LEDS on each side in the front map lights then 8 in each dome light in the back. How ever i did put one of the 4led x 4 led grids in my grandfathers truck and they were pretty bright.And have you offered your services to the board members yet?
Re: (Water boy)
Posted: Fri Feb 25, 2011 5:47 am
by joshuaeb09
No i would actually recommend the premade solutions as I hard wired all my stuff in and in reality only saved like 10 bucks at most. With replacement bulbs its not so permanent. But I have had good luck with most of the leds bulbs from ebay in friends/family members cars. Im a big fan of the large led grids that go in the dome i know my elderly grandfather loves them (he cant see so well in low light anymore). I did mine more for looks than functionality to be honest with you.
Re: (joshuaeb09)
Posted: Fri Feb 25, 2011 7:16 am
by Water boy
Quote, originally posted by joshuaeb09 » But I have had good luck with most of the leds bulbs from ebay ... Care to share your source?
Re: (Water boy)
Posted: Fri Feb 25, 2011 3:20 pm
by joshuaeb09
Quote, originally posted by Water boy »Care to share your source?When ever I order I usually just go to ebay motors under LED lighting and type in a bulb number. As long as the seller has good reviews and the bulbs look solid (Have plenty of LED's, build quality looks good, etc.) I will give them a shot. For my interior glow under my dash and seats I used a store called sisi -
http://stores.ebay.com/sisi-bu....m322 For my Licence plate bulbs I just bought the cheapest 10 LED bulb i could find.
Re: (joshuaeb09)
Posted: Fri Feb 25, 2011 11:49 pm
by Water boy
