Gas tank cover
Posted: Wed Jun 25, 2003 10:16 pm
by ullbergm
Seems like there was a topic about this a while back but i couldnt find it..Is the vibe supposed to have that thin little cover over the gas tank that is pushed aside when you fill up?For some reason i thought that i used to have one, but this morning i didnt see one.. am i dreaming or are we supposed to have one?
Re: Gas tank cover (ullbergm)
Posted: Wed Jun 25, 2003 10:20 pm
by Triton
I don't think the Vibe has one. I don't remember seeing one in mine and I fill up every week on Tuesday. I'll have to check again.
Posted: Wed Jun 25, 2003 10:34 pm
by NovaResource
Do you mean the little metal flap that cover the hole? I thought so to but it doesn't.
http://forums.genvibe.com/zerothread?id=767
Re: Gas tank cover (NovaResource)
Posted: Wed Jun 25, 2003 10:43 pm
by ullbergm
There's the topic i couldnt find..I even replied to it last time Good, i didnt want to have some piece of metal in my gastank.
Posted: Wed Jun 25, 2003 10:48 pm
by esjones
quote:Seems like there was a topic about this a while back but i couldnt find it..Is the vibe supposed to have that thin little cover over the gas tank that is pushed aside when you fill up?For some reason i thought that i used to have one, but this morning i didnt see one.. am i dreaming or are we supposed to have one?I think that metal flap is an anti-siphon device. It wouldn't be necessary in a car like the Vibe which has a latching fuel cover that can only be released from inside the car.
Re: Gas tank cover (esjones)
Posted: Thu Jun 26, 2003 12:54 am
by NovaResource
quote:I think that metal flap is an anti-siphon device. It wouldn't be necessary in a car like the Vibe which has a latching fuel cover that can only be released from inside the car.It's not an anti-siphon device, it's an anti-splash device used to prevent fuel spills.
Posted: Thu Jun 26, 2003 6:46 am
by Vibe Rater
quote:I think that metal flap is an anti-siphon device. It wouldn't be necessary in a car like the Vibe which has a latching fuel cover that can only be released from inside the car.It's not an anti-siphon device, it's an anti-splash device used to prevent fuel spills.You are correct sir. Kinda makes one wonder why the VIBE doesn't have one.
Re: Gas tank cover (Vibe Rater)
Posted: Thu Jun 26, 2003 6:51 am
quote:It's not an anti-siphon device, it's an anti-splash device used to prevent fuel spills.You are correct sir. Kinda makes one wonder why the VIBE doesn't have one.Not sure how that ever prevented fuel spills because it's pushed aside during filling, and after filling, you replace the fuel cap...so I dunno...
Re: Gas tank cover (ragingfish)
Posted: Thu Jun 26, 2003 1:11 pm
by NovaResource
quote:Not sure how that ever prevented fuel spills because it's pushed aside during filling, and after filling, you replace the fuel cap...so I dunno...It was first used in the 70's when gas filler tubes were usually in the rear of the car behind the license plate. When a car accelerated fuel would move to the back of the tank and sometimes out the filler tube. Remember, gas tanks weren't sealed back then so fuel could leak out even with the cap on. All you have to do is watch 60's car at the drag strip and you'll usually see one spewing fuel at the beginning of the track.
Posted: Thu Jun 26, 2003 1:19 pm
Makes sense. Thanks Nova!
Re: Gas tank cover (silverawd26)
Posted: Fri Jun 27, 2003 10:42 am
by engine1
There are no baffles in the fuel tank but the fuel pump does have a "sock" or "strainer" to screen out large chunks and/or debris! So i wouldn't worry about your fuel pump it will be fine, the hardest thing on a FP is driving with less than an 1/4 tank. As the gas acts a a coolant to keep the pump working cool and properly, when the gas gets below a quarter tank it's sitting below the pump not surrounding it, not getting the total cooling effect. Now granted this doesn't sound terribly bad in the grand scheme of things, when you figure a fuel pump replacement is going to be at least a thousand dollars it starts to become something you think about more seriously! Most modern cars have the fuel pump/fuel sender assemblies manufactured as one unit (just ask any Dodge Caravan owner who has had to replace his) and most are worth 500-600 bucks PLUS the install!!!!!
