Reposition rear wiper
Posted: Thu Feb 17, 2011 1:51 am
by wizardai
At some point in the early history of the car (previous owner) the rear wiper was moved to about a -45 degree angle. So, when you use it, it goes onto the hatch instead of cleaning only the glass! lolAny idea on how to open up the case it's in and move it over to it's correct "flat" position?"tia!
Re: Reposition rear wiper (wizardai)
Posted: Thu Feb 17, 2011 2:06 am
by 06pvibe
Sure! An easy one.... First, gently pry up the cover from the back, or bottom of the wiper arm. It will hinge upward approx 90* where the arm itself is hinged.Next, loosen the nut you will find under there, usually a 10mm. Third, lift the arm slightly from the post and reset it to its proper resting place. Fourth, re-torque the nut. Five, clip the cover back into place. Remember that it is plastic and has likely been out in the weather most/all of its life so it may be brittle. No great loss if you lose it though, just not as pretty.You might want to make sure the ignition and wiper switches are in the off position before you begin. It can be hard to reset a wiper arm when the lil' sucker keeps moving on ya'.
Re: Reposition rear wiper (06pvibe)
Posted: Thu Feb 17, 2011 2:16 am
by wizardai
hah! I'll make sure they wiper's not moving and out of the rain! I will try this out when I get home tonight.Thanks for the info!
Posted: Thu Feb 17, 2011 3:43 am
by jkm311
And something the previous owner probably did was try to engage the rear wiper when it was frozen to the glass, or covered in a foot of snow. Something I know you won't do!
Posted: Thu Feb 17, 2011 3:48 am
by 06pvibe
Rain? Snow? Ice?In Southern California?? LOLZ
Posted: Thu Feb 17, 2011 4:02 am
by jkm311
Never know where a used car could come from... and yes, certain parts of California have seen a lot of snow this month alone! So hard to believe.
EASY!!
Posted: Thu Feb 17, 2011 11:25 am
by wizardai
Amazing how easy the fix was. I had been looking inside the hatch panel, thinking it'd have to be in/around the motor LOL! Thanks so much! Here's some pictures for your trouble...Before http://bayimg.com/cadmfaado.jpgAfter http://bayimg.com/cadmlaado.jpgThanks again!* Edit - I can't get the thumbnails to work for some reason. Pretty weird.
Re: EASY!! (wizardai)
Posted: Thu Feb 17, 2011 6:21 pm
by 06pvibe
Now see? I told you it wasn't that hard. You're welcome, and a BIG Congrats on the fix. And the good thing is now you know how for most cars out there today, front or rear.
