CEL p2441 code help
Posted: Tue Feb 15, 2011 2:01 am
by CRW
Hi,I have an unmodified Vibe GT and pulled code p2441 from it today. I've found a lot of info in this forum but mostly seemed related to people that have done CAI's. My Vibe GT is stock.Any suggestions on where to start in trying to troubleshoot the issue?Thanks!
Re: CEL p2441 code help (CRW)
Posted: Tue Feb 15, 2011 8:55 am
by dgekiere
unfortunatly this doesn't look like it gonna transfer rightDTC P2441 System DescriptionThe DTC P2441 Secondary Air Injection (AIR) System Shut-Off Valve Stuck Closed diagnostic monitors the operation of the AIR shut-off valve. The secondary AIR system helps reduce exhaust emissions. The system forces fresh filtered air into the exhaust stream in order to accelerate the catalyst operation. An electric air pump, the secondary AIR injection pump, provides filtered air on demand to the AIR shut-off valve. The AIR shut-off valve controls the flow of air from the AIR pump to the exhaust manifold. The AIR solenoid valve supplies the manifold vacuum that is used to operate the AIR shut-off valve. A pressure sensor is used to monitor the air flow from the AIR pump. By comparing the measured pressure against the expected pressure the pressure sensor can detect faults in the AIR pump, AIR shut-off valve, and the AIR solenoid valve. The pressure sensor can also detect leaks in the secondary AIR system plumbing.Conditions for Running the DTC • The engine is running. • The secondary AIR solenoid valve is commanded ON. • DTC P2441 runs every time the above conditions have been met. Conditions for Setting the DTCThe pressure sensor does not detect exhaust gas pulsations when the AIR shut-off valve should be OPEN.Action Taken When the DTC Sets • The PCM turns OFF the MIL on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present. • The PCM records the operating conditions at the time the diagnostic fails. This information is stored in the Freeze Frame buffer. Conditions for Clearing the MIL/DTC • The PCM turns OFF the MIL on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present. • A DTC will clear after 40 consecutive warm-up cycles have occurred without a fault. • A DTC can be cleared by using the scan tool Clear Information function. Test DescriptionThe numbers below refer to the step numbers on the diagnostic table.The Diagnostic System Check-Engine Controls prompts the technician to complete some basic checks and store the Freeze Frame data on the scan tool if applicable. This creates an electronic copy of the data taken when the fault occurred. The information is then stored in the scan tool for later reference.This step verifies the operation of the secondary AIR solenoid valve.This step verifies the correct operation of the secondary AIR shut-off valve.This step verifies the operation of the vacuum check valve.Step Action Values Yes No Schematic Reference: Engine Controls Schematics Connector End View Reference: Powertrain Control Module Connector End Views or Engine Controls Connector End Views 1 Did you perform the Diagnostic System Check-Engine Controls? -- Go to Step 2 Go to Diagnostic System Check - Engine Controls 2 Install a scan tool and check for DTCs.Is DTC P2430, P2431, P2432, or P2433 present? -- Go to DTC P2430 , DTC P2431, DTC P2432or DTC P2433 Go to Step 3 3 Disconnect the vacuum hose at the secondary AIR shut-off valve. Connect a vacuum gauge the vacuum hose. Start the engine. Command the AIR solenoid valve and the AIR pump ON with the scan tool. Refer to Scan Tool Output Controls. Did the vacuum gauge indicate pressure when the AIR pump was ON? -- Go to Step 8 Go to Step 4 4 Turn OFF the ignition. Disconnect the vacuum supply hose at the secondary AIR solenoid valve. Connect the vacuum gauge the vacuum supply hose. Start the engine. Did the vacuum gauge indicate pressure with the engine running? -- Go to Step 5 Go to Step 10 5 Turn OFF the ignition. Disconnect the other vacuum hose from the AIR solenoid valve and connect the vacuum gauge to the vacuum port. Reconnect the vacuum supply hose to the AIR solenoid valve. Start the engine. Command the AIR solenoid valve and the AIR pump ON with the scan tool. Did the vacuum gauge indicate pressure when the AIR pump was ON? -- Go to Step 12 Go to Step 6 6 Turn OFF the ignition. Disconnect the electrical connector of the AIR solenoid valve. Connect a test lamp between the ignition positive voltage circuit of the AIR solenoid valve and a known good ground. Refer to Troubleshooting with a Test Lamp in Wiring Systems. Turn ON the ignition, with the engine OFF. Did the test lamp illuminate? -- Go to Step 7 Go to Step 14 7 Connect a test lamp between the ignition positive voltage circuit and the control circuit of the AIR solenoid valve. Refer to Troubleshooting with a Test Lamp in Wiring Systems. Command the AIR solenoid valve and the AIR pump ON with the scan tool. Did the test lamp illuminate when the AIR solenoid valve and AIR pump were commanded ON? -- Go to Step 16 Go to Step 13 8 Turn OFF the ignition. Remove the secondary AIR shut-off valve. Refer to Secondary Air Injection Shutoff Valve Replacement. Connect a hand vacuum pump to the vacuum hose port of the AIR shut-off valve. Apply the specified value of vacuum to the AIR shut-off valve. Blow air into the large port on the AIR pump side of the AIR shut-off valve. Did the air pass through the AIR shut-off valve? 45 kPa (13.3 in Hg) Go to Step 9 Go to Step 18 9 Test for a leak, a blockage, or a restriction in the air hose and pipe assembly from the AIR shut-off valve to the exhaust manifold. Repair as necessary. Did you find and correct a condition? -- Go to Step 21 Go to Intermittent Conditions 10 Inspect for the correct installation of the vacuum check valve. The BLACK side of the check valve should be towards the intake manifold.Did you find and correct a condition? -- Go to Step 21 Go to Step 11 11 Remove the vacuum check valve. Connect a hand vacuum pump to the BLACK side of the check valve. Apply vacuum to the check valve. You should not be able to hold vacuum. Connect the hand vacuum pump to the other side of the check valve. Apply vacuum to the check valve. You should be able to hold vacuum. Did the check valve pass both tests? -- Go to Step 12 Go to Step 15 12 Repair the leak, blockage, or restriction in the vacuum supply hose between the AIR solenoid valve and the intake manifold.Did you complete the repair? -- Go to Step 21 -- 13 Test for an open in the control circuit of the AIR solenoid valve. Refer to Circuit Testing in Wiring Systems. Repair as necessary. Refer to Wiring Repairs in Wiring Systems. Did you find and correct the condition? -- Go to Step 21 Go to Step 19 14 Repair the open or short to ground in the ignition positive voltage circuit of the AIR solenoid valve. Refer to Wiring Repairs in Wiring Systems.Did you complete the repair? -- Go to Step 21 -- 15 Replace the vacuum check valve. Did you complete the replacement? -- Go to Step 21 -- 16 Test for an intermittent and for a poor connection at the AIR solenoid valve. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.Did you find and correct the condition? -- Go to Step 21 Go to Step 17 17 Replace the secondary AIR solenoid valve. Refer to Secondary Air Injection Solenoid Valve Replacement.Did you complete the replacement? -- Go to Step 21 -- 18 Replace the secondary AIR shut-off valve. Refer to Secondary Air Injection Shutoff Valve Replacement. Did you complete the replacement? -- Go to Step 21 -- 19 Test for an intermittent and for a poor connection at the control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.Did you find and correct the condition? -- Go to Step 21 Go to Step 20 20 Replace the PCM. Refer to Powertrain Control Module Replacement.Did you complete the replacement? -- Go to Step 21 -- 21 Use the scan tool in order to clear the DTCs. Turn OFF the ignition for 30 seconds. Start the engine. Operate the vehicle within the Conditions for Running the DTC. Did a DTC P2441 set? -- Go to Step 2 Go to Step 22 22 With a scan tool, observe the stored information, Capture Info.Does the scan tool display any DTCs that you have not diagnosed? -- Go to Diagnostic Trouble Code (DTC) List System OK
Posted: Tue Feb 15, 2011 11:16 am
by dgekiere
heres the wiring diaram for the solenoid valve
