				TPMS reset ... NOT
				Posted: Sun Feb 06, 2011 7:37 am
				by Water boy
				Am I the only one who can't reset the TPMS idiot light on my '08?I've followed the owners manual.I get the 3 blinks.I know the tire PSI is correct at 32 on all 4.What am I missing?
				Re: TPMS reset ... NOT (Water boy)
				Posted: Sun Feb 06, 2011 8:47 am
				by Cruxless
				Have you checked your spare tire?  Some spares are equipped with tpms sensors and they can cause the tpms warning light if not properly inflated.
				Posted: Sun Feb 06, 2011 11:54 am
				by BurnOnyx08
				Had to do this many times in my '08, with the aluminum rims I tend to lose a lot of air. Inflate to preferred pressure. Begin driving. Hold button for a good 5 seconds and it should calibrate in the next few miles. I'm positive there is no TPMS in the spare as I had it on all 4 corners due to the OEM tires being crap. This is not the way the manual says to do it, but it works for me.
				Posted: Sun Feb 06, 2011 12:59 pm
				by ehoff121
				Quote, originally posted by Water boy »I know the tire PSI is correct at 32 on all 4.Please double check your pressure- my '05 has 35 PSI on the fronts and 32 PSI on the rears.You also need to drive over a certain speed for an hour or two as in the manual.Apparently, the '08 has TPMS sensors in the tire valve unlike the previous generations. Could it be a malfunctioning sensor?
				Posted: Mon Feb 07, 2011 1:34 am
				by lovemyraffe
				Quote, originally posted by Water boy »What am I missing?Follow the directions in the manual. It takes more than just pushing the button on the dash. I think it wants you to drive for an hour or so, like others have said.
				Posted: Mon Feb 07, 2011 6:14 am
				by Water boy
				So, what is the sequence you believe works?PSI checkedResetDriveDid that.No fixy.
				Re: TPMS reset ... NOT (lovemyraffe)
				Posted: Mon Feb 07, 2011 6:15 am
				by Water boy
				Any way to discover if there is a bad sensor?
