Where did I see this?
Posted: Fri Feb 04, 2011 8:04 am
by zubenal
I saw in this forum a discussion on a plug that I think is in the block that is removed to allow more sludgy oil to drain. Doing this, I read, improves the performance.I cant find that thread. There was even a diagram to show where the plug is.Can someone point me to this?Thanks
Re: Where did I see this? (zubenal)
Posted: Fri Feb 04, 2011 8:07 am
by 04chargedvibe
If i remember correctly i believe its this onehttp://forums.genvibe.com/zerothread?id=42494
Re: Where did I see this? (04chargedvibe)
Posted: Fri Feb 04, 2011 10:39 am
by zubenal
YESSSSS.Thanks.I have to print out the diagram to show it to my mechanic.
Posted: Fri Feb 04, 2011 2:46 pm
by DoubleBaril
im guessing this has to be done at the time of an oil change?
Re: (DoubleBaril)
Posted: Sat Feb 05, 2011 2:02 am
by millster
Quote, originally posted by DoubleBaril »im guessing this has to be done at the time of an oil change? Not necessarily. Oil is only flowing through this while the pump is running. I'd question whether, for the normal owner, any "performance increase" would be noticed by cleaning the valve and filter. If you've been lax on maintenance, possibly. Mostly, this valve becomes suspect in cases of the engine "falling on its face" in the RPM ranges where the valve timing is varied (the first of which is right around 3,000 IIRC).
Re: (millster)
Posted: Sat Feb 05, 2011 3:44 am
by NascarXprt
if i am having bad mpg (around 25-27) would this improve my MPG if i were to clean and replace it? BTW i have 110,000 miles on the car.
