05 vibe with a rattle in the trans...
Posted: Mon Jan 24, 2011 8:26 am
by vibolista
My son decided to change the trans oil in his manual 05 Vibe. It looked like it had not been done in some time. The stuff that he drained out was gross.Now after the new trans oil went in, there's an intermittent rattle coming from inside the housing when the clutch is not depressed. Depress the clutch, and the noise goes away. What could cause this? Any ideas?
Re: 05 vibe with a rattle in the trans... (vibolista)
Posted: Mon Jan 24, 2011 8:36 am
by star_deceiver
Did he get the correct amount of fluid back in there? Was it the correct type of oil? Does it make the noise while driving or just idling in neutral?
Re: 05 vibe with a rattle in the trans... (star_deceiver)
Posted: Mon Jan 24, 2011 9:07 am
by vibolista
He had the use of a friend's lift. Proper transmission oil. Car was level. Filled it until it ran out. I asked him the same thing. He notes nothing different while driving, shifting, starting out. Everything "feels" normal. Just that rattly noise when the car idles in neutral... I heard it this evening. An on and off rattle that has no pattern. Push the clutch in and you hear quiet.Can't hear it driving.
Posted: Mon Jan 24, 2011 9:17 am
by star_deceiver
Well... is there anything around the transmission heat-shield wise or one of the cables that could be loose? It could be that the new oil has freed up some of the shifter forks. Drive it for a bit, see what happens. Maybe in a couple hundred miles change to a heavier oil.
Posted: Mon Jan 24, 2011 9:57 am
by vibolista
This is scary, now SD. I just called and told him to drive it a while longer, and if the noise doesn't go away in a few days, to change oil again and use a different brand.At least it's not having any negative effects. Yet.
Posted: Mon Jan 24, 2011 10:03 am
by star_deceiver
Alright... let's see how weird this gets....I'd recommend this as a replacement oil:
Posted: Tue Jan 25, 2011 12:23 am
by lovemyraffe
Quote, originally posted by vibolista »Filled it until it ran out.Filling until it runs out doesn't mean that the proper amount is in. Double check the levels while the fluid is warm, in neutral and on a level surface.
Re: 05 vibe with a rattle in the trans... (lovemyraffe)
Posted: Tue Jan 25, 2011 7:57 am
by frankiemenz
If the noise goes away by just applying pressure to the clutch pedal with 2 fingers and pressing a little more but not enough to totally disengage the clutch then I suspect some noisey clutch fingers, springs or throwout bearing rattle. I mean pressing the pedal no more than 1 inch with the engine running.
Posted: Tue Jan 25, 2011 2:13 pm
by Sublimewind
Quote, originally posted by vibolista »My son decided to change the trans oil in his manual 05 Vibe. It looked like it had not been done in some time. The stuff that he drained out was gross.Now after the new trans oil went in, there's an intermittent rattle coming from inside the housing when the clutch is not depressed. Depress the clutch, and the noise goes away. What could cause this? Any ideas? clutch throw out bearing... Why, I can't say, but that's what you are describing..
