what is the correct power steering fluid?
Posted: Fri Jan 21, 2011 8:19 pm
by woodyg
can someone please tell me the correct power steering fluid to use . the OM says Dextron III. but it is also says to use Dexcool coolant and that appears to be wrong.......
Re: what is the correct power steering fluid? (woodyg)
Posted: Fri Jan 21, 2011 9:23 pm
by keithvibe
it's the same as your tranmission fluiddexron IIIFor a good reference point go to amsoil.com and enter your car's info and it will build a list of fluid recommendations.
Re: what is the correct power steering fluid? (keithvibe)
Posted: Fri Jan 21, 2011 9:45 pm
by woodyg
Quote, originally posted by keithvibe »it's the same as your tranmission fluiddexron IIIFor a good reference point go to amsoil.com and enter your car's info and it will build a list of fluid recommendations.thanks......i bought it with 110k on it. I now have 143k.........about 4 or 5 times I have gone to toyota and bought their type iv($5 each) and did a drain and fill.........should I have and could I have used Dextron III. any issues with using the toy type iv?
Posted: Sat Jan 22, 2011 5:39 am
by zionzr2
our auto tranny uses Toyota type IV, the Power Sterring uses Dexron III tranny fluid. make sure the bottle says its compatible to the right type. There are fluids that are compatible for both. I use the Royal Purple ATF fluid which covers both dexron III and toyota type IV fluids.
Re: what is the correct power steering fluid? (zionzr2)
Posted: Sat Jan 22, 2011 6:36 am
by woodyg
Quote, originally posted by zionzr2 »our auto tranny uses Toyota type IV, the Power Sterring uses Dexron III tranny fluid. make sure the bottle says its compatible to the right type. There are fluids that are compatible for both. I use the Royal Purple ATF fluid which covers both dexron III and toyota type IV fluids.thanks I have been using toyota type iv in the tranny.....I will get some Dextron iii and flush out the powersteering in the spring .....
Posted: Sat Jan 22, 2011 11:11 am
by keithvibe
I use amsoil and it too is good for both.BTW less than 10 posts till I hit the 5k mark.
Posted: Wed Jun 29, 2011 9:13 am
by woodyg
I finally got around to doing this. I unhooked the return line and attached a plastic hose to the nipple. I had my kid start the car and I pumped out the old power steering fluid. it was nasty. a kind of mud color. I pumped though a couple of quarts of ATF. the whole thing took less than 20 minutes......I suggest you consider doing it. I could not see in the reservoir very well so I did not know had bad it was...thanks for the help
