mounting subs
Posted: Wed Jan 19, 2011 11:11 am
by pyro
im going to be purchasing an 03 vibe in the next few days and ive got 2 sub tubes with 12s in them. theyre pretty big... probly 16" diameter and about 1.5' long. any ideas on how to mount these things? id rather not screw stuff into plastic or do any irreversible mods but i dont want these things just rolling around back there. let me know what you think i can post pics or give exact measurements if needed
Posted: Wed Jan 19, 2011 11:36 am
by torker
Only thing I can think of is using the factory d-rings and using some kind of a strap eg. small ratchet strap
Posted: Wed Jan 19, 2011 12:21 pm
by jayman2009
i have my sub box curently help by a ratchet strap been to buzy to mount it
Re: (torker)
Posted: Wed Jan 19, 2011 1:40 pm
by A Psycho Martyr
Quote, originally posted by torker »Only thing I can think of is using the factory d-rings and using some kind of a strap eg. small ratchet strapHe said it. You have the 4 d-rings, or the mounting things on the back of the rear seats. They have little things that screw into them and provide great mounting points
Posted: Fri Jan 21, 2011 11:03 am
by pyro
sounds good. im thinking of strapping them on each side (see my attached picture for exactly what i mean). and id like to try to put my amp on top of the wheel well somehow...im just throwing out my initial idea... what does anyone think?
Posted: Fri Jan 21, 2011 12:44 pm
by audiovibe
I would drill 2 holes in each enclosure.Then I would get some bolts that are the same thread pitch as the factory anchors.Then I would screw the enclosures to the factory anchor lugs.
Posted: Sat Jan 22, 2011 12:52 am
by torker
Now that is a more solid idea than mine.. Although straps would allow you easier access to the spare.
Posted: Mon Feb 07, 2011 11:39 am
by Serj22
That's the biggest capacitor I've ever seen in my life. May I make a suggestion as to putting it in one of the side cubby's, cutting a piece of plexiglass to fit instead of the door, then tinting the glass with VHT nightshades, and putting an LED inside to light it when the remote switch is on for the amps. Hidden when off.
Posted: Mon Feb 07, 2011 9:05 pm
by Sublimewind
Don't bother with the cap and call it good.. They are basically worthless these days, I'll explain why if need be... Not dissin anything, I used to run caps, till I learned better.. jus sayin..
Re: (audiovibe)
Posted: Mon Feb 07, 2011 9:09 pm
by Sublimewind
Quote, originally posted by audiovibe »I would drill 2 holes in each enclosure.Then I would get some bolts that are the same thread pitch as the factory anchors.Then I would screw the enclosures to the factory anchor lugs.Aron, think about that for a sec bro, if they wearn't up against the sides, it would be far to riged of a mount, after a few turns, the bolts would rip through...
Re: (Sublimewind)
Posted: Tue Feb 08, 2011 5:36 am
by audiovibe
Quote, originally posted by Sublimewind »Aron, think about that for a sec bro, if they wearn't up against the sides, it would be far to riged of a mount, after a few turns, the bolts would rip through... OOPS, I didn't comprehend the enclosures are round the first read. They would have a tendency to want to roll when the car turned.Thanks for catching that Aaron!
