Best way to fix this...
Posted: Fri Jan 14, 2011 1:46 am
by bax08
My vibe has a little over 97,000 miles on it and the interior is holding up very nicely, except for what you see in the pics. Before I go slapping some super glue on this, I as wondering if there might be a better way to fix this?
Posted: Fri Jan 14, 2011 1:54 am
by Wolfman213
Finish popping it out and see if the clip is still there. If I remember right, it's kind of finicky on getting put back into place.
Re: Best way to fix this... (bax08)
Posted: Fri Jan 14, 2011 2:00 am
by ou.grizzly
I think that part has broke on everyone's Vibe.
Re: Best way to fix this... (ou.grizzly)
Posted: Fri Jan 14, 2011 2:21 am
by lovemyraffe
Quote, originally posted by ou.grizzly »I think that part has broke on everyone's Vibe. Mine are broken on both the drivers and passenger side.
Posted: Fri Jan 14, 2011 2:27 am
by Wolfman213
I must be lucky then bc I've popped mine out SEVERAL times and still not broke *knock on wood*
Posted: Fri Jan 14, 2011 2:30 am
by epcIII
Mine was broken too and it really bothered me. So I put the tiniest of screws through it and into some plastic underneath. If I painted the screw solver you would hardly notice it. Reason I didn't glue it was sometimes you need to take that off if you need to fix something in the door.
Posted: Fri Jan 14, 2011 5:14 am
by bassplayaz06
i actually just fixed this on wednesday. all the clips on the right side of it and the one on the back were gone. i got some plastic epoxy and glued some peices of plastic similar to the original clips where they went. let it sit for a day and it was perfect.
Posted: Sat Jan 15, 2011 12:17 am
by DiveNut
Mine broke too...I cut a few strips of velcro to hold it in place. Not fancy, but wht.
Re: Best way to fix this... (DiveNut)
Posted: Sun Jan 16, 2011 11:03 am
by mac99d
+1 for broke
Posted: Sun Jan 16, 2011 2:52 pm
by DJ_Losch_411
Dang, I guess i got a lucky vibe lol, 130,000 on my GT and interior is still strong... *knock on wood also*
Posted: Sun Jan 16, 2011 11:46 pm
by bax08
Sounds like the best solution is to use velcro or just let it be. Thanks for the replies!
Posted: Tue Jan 25, 2011 10:25 pm
by DeClerq
The front clip on mine broke so every time I tried to raise the window the whole assemble would pull out. The plastic piece that hangs down was still there (I think I there was a metal clip that attached that piece of plastic and it went missing). I took the door panel off and then put a small screw through that plastic piece. The screw is just big enough to keep the panel from raising up any. No problems with it since.
Re: Best way to fix this... (DeClerq)
Posted: Tue Jan 25, 2011 11:50 pm
by scherry2
Quote, originally posted by DeClerq »The front clip on mine broke so every time I tried to raise the window the whole assemble would pull out. The plastic piece that hangs down was still there (I think I there was a metal clip that attached that piece of plastic and it went missing). did you check in the door for the clip? cause if the clip came off it fell in the door not out.
Posted: Wed Jan 26, 2011 12:04 am
by keithvibe
No issue with mine yet... had it out three times now
Posted: Wed Jan 26, 2011 3:11 am
by kostby
I ordered a new one from the dealer a couple of years ago. I think it was around $30, but they installed it for free because it was the same time as the window recall, so they had to take the door apart anyway.
Re: Best way to fix this... (scherry2)
Posted: Wed Jan 26, 2011 5:30 am
by DeClerq
Quote, originally posted by scherry2 »did you check in the door for the clip? cause if the clip came off it fell in the door not out.I looked, couldn't find it anywhere. Hence my screw solution.
Posted: Sun Feb 06, 2011 5:11 am
by Guitarheroal
the back side clip of mine is completely broken off. i bought some loctite general purpose automotive adhesive. you guys recommend using it? I dont think i will be needing to fix anything in the door
Posted: Mon Feb 07, 2011 6:08 am
by Guitarheroal
bump! i'll probably just try using it tomorrow anyway if no one responds
Re: (Guitarheroal)
Posted: Tue Feb 08, 2011 1:49 am
by Ls1jorge
+10 yup mines broke 3weeks ago driverside door,
Re: (Guitarheroal)
Posted: Tue Feb 08, 2011 2:16 am
by bassplayaz06
if you have some epoxy, do what i did. easiest if you even wanna think about taking it back out.
Posted: Tue Feb 08, 2011 3:55 am
by Guitarheroal
i wish i could, but the clip on the panel broke off as well as where the clip goes into. I have no idea where they went either. i might be sol and will try to just glue it on.
Posted: Tue Feb 08, 2011 9:07 am
by MotoAce51
Mine was getting loose and I was getting annoyed and I tried to take it off and it officially broke. Its too darn cold out right now to do anything with it so I tried the velcro idea. Works well. Its not perfect but I am happy for now. I will prob get a new one in the summer but the velcro works really well. You just need to get some good stuff not cheap.
Re: (bassplayaz06)
Posted: Tue Feb 08, 2011 11:04 am
by Guitarheroal
Quote, originally posted by bassplayaz06 »if you have some epoxy, do what i did. easiest if you even wanna think about taking it back out.oo nvm, found the broken piece. going to try to epoxy it back on, but it looks like an extremely cheap piece. hope it holds!
Posted: Sun Mar 13, 2011 5:35 am
by jesshaun
Anyone know where to find a replacement piece before I just buy some velcro for it?
Re: (jesshaun)
Posted: Tue Mar 15, 2011 6:21 pm
by IMakeVibes
Quote, originally posted by jesshaun »Anyone know where to find a replacement piece before I just buy some velcro for it?Junkyard or dealer? And yes, mine was broke when I got the Vibe and its more broke now...
Re: (Guitarheroal)
Posted: Wed Mar 16, 2011 6:47 am
by bassplayaz06
well, mine was fine til the dealership decided to break it again.... i used some weak epoxy so it busted off. i'll get some velcro or something on there tomorrow.
Posted: Wed Mar 16, 2011 10:20 am
by MotoAce51
The velcro is only a temp fix. Mine is coming loose again. But its warming up now and I will get a replacement part. Its annoying when it shifts off to the side.
Posted: Sun May 22, 2011 8:58 am
by bax08
Does anybody know the part # for this piece? Do the vibe and matrix use the same part? The reason I ask is b/c it appears the matrix part is much cheaper than the vibe part, $14.16 vs. $57.02.
