Part Number Help! (Integration Relay)
Posted: Tue Jan 04, 2011 6:40 am
by MikeMcC
Hey Guys,I had a mishap while installing a stereo system/speakers in my wife's car, and as a result, fried the integration relay. I'd love to replace it, but I can't for the life of me find it online. Toyota calls it an Integration Relay, and Pontiac/GM calls it a "Multi-Function Alarm Module". I can't find a source when searching for either.The part number and labeling off the module is clearly Toyota marked. Specifically P/N 82641-01090. I've been to the junk yards in the area and can't seem to find one off an 04 Vibe/Matrix, and when I call around, none of them know the part I'm looking for. I've also tried eBay and craigslist to no avail. I've even looked for just the under dash fuse box in the hopes some parts monkey can't tell the two components apart, but still come up empty handed.Any ideas, or sources for integration relays?
Re: Part Number Help! (MikeMcC)
Posted: Tue Jan 04, 2011 10:22 am
by epcIII
Welcome to the site!How about this: 88973138 MFAM (Multi Function Alarm Module)?From this great thread: http://forums.genvibe.com/zerothread?id=9923 Good luck.
Re: Part Number Help! (epcIII)
Posted: Tue Jan 04, 2011 2:45 pm
by 808 Vibes
Welcome Hold on...I'll send out the bat signal for the parts master...
Posted: Tue Jan 04, 2011 5:36 pm
by MikeMcC
epcIIIThanks so much for the response. I had seen that thread, but was unsure how to align my Toyota branded module to the GM part number. My fear is that if I don't get the exact Toyota branded part, the Keyless entry still won't work.I was able to go double check the part number last night when my wife got home from work. It looks like I was off a digit. The part number is actually 82641-01070 I snapped a pic just for verification:
Posted: Wed Jan 05, 2011 4:49 am
by Salsa Guy
Guy on MO found it! Here's the link http://matrixowners.com/index....09773Hope it works!
Posted: Wed Jan 05, 2011 7:40 pm
by MikeMcC
Hey rmckinjr,Thanks for the notify on that. Unfortunately I can't confirm the P/N that the person on MO provided will work. See below if anyone else runs into this problem. Just in case anyone else runs into this, or finds this via Google or some other means, I was able to find a replacement. It seems that GM has decommissioned that part number, and will not be making/ordering any more parts from Denso. One of the more helpful folks that I talked with thought that the 01040 relay would work, but I wasn't going to take a chance on that. I probably talked to 20 or so folks in both GM and Toyota parts and decided it wasn't worth it.I ended up using Car-Parts.com and searching for "Electrical - Misc Wiring/Electrical" and found several listings for fuse boxes on the 04 vibes. I was lucky enough to find a listing that had the 01070 p/n listed and got it for $100 shipped.Hopefully I'll be back in the good graces of my wife once I get the relay back in, and get the FOBs reprogrammed.
