Little problem with my 2009 Vibe...
Posted: Mon Jan 03, 2011 10:45 pm
by Eloi
Did this happen to anyone living in places with cold weather? This morning, for the third time in the last couple weeks, when I started the engine at -10°C, the front wipers didn't work. They were not jammed with ice or anything, they just didn't work, even when trying to move them manually outside. Then, when the car has heated a bit, a few kilometers away, on my way to the garage to have them checked, they started to work. I talked to the guy at the local station and since they were working, it was hard to find the problem. He said maybe it could be the wiper "motor" that could be defective. Like I mentioned, it also happened 2 times before when the wipers came back to life when the car had heated a bit.Anyone knows what could be the problem? If it's indeed the wiper's motors, is it guaranteed by GM? I'll have my car for 3 years this April, and the odometer reads 79,000 km. First problem ever with this nice car.Thanks.
Re: Little problem with my 2009 Vibe... (Eloi)
Posted: Mon Jan 03, 2011 11:54 pm
by jake75
I am not sure, but I think if you reported the problem (get that documented) they will still fix it under warranty after the warranty expires.
Posted: Tue Jan 04, 2011 8:28 am
by star_deceiver
Never had that problem. Was there snow on the windshield?
Posted: Tue Jan 04, 2011 12:35 pm
by csxt8058
I'm on my second winter with my 2010 AWD, never had a problem like that either. Hope it's something simple. JR
Re: Little problem with my 2009 Vibe... (star_deceiver)
Posted: Tue Jan 04, 2011 9:42 pm
by Eloi
Quote, originally posted by star_deceiver »Never had that problem. Was there snow on the windshield?No snow on the windshield at all.And you know what? This morning, it was colder than yesterday (-14°C) and the wipers were working just fine.This is really weird...
Posted: Wed Jan 05, 2011 2:48 am
by jake75
Quote, originally posted by Eloi »No snow on the windshield at all.And you know what? This morning, it was colder than yesterday (-14°C) and the wipers were working just fine.This is really weird...The healing powers of GenVibe.
Re: Little problem with my 2009 Vibe... (jake75)
Posted: Wed Jan 05, 2011 3:28 am
No problems of such on my Vibe either although not quite as cold as what you're experiencing up there. One thing that I did notice was a slight rattle/squeal in the blower motor at ANY speed. Once the car is warmed up it goes away. Clearly something to do with temperature and the expansion/contraction of parts. Not a real big deal but something I just noticed
Posted: Thu Jan 06, 2011 3:01 am
by Eloi
It did it again this morning. Looks like the humidity might be more of a problem than the cold weather itself. Or probably the combination of the two.In any ways, I'm starting looking for the windshield wipers' motor. First, is there one motor for both wipers or do they have one motor each? Second, someone told me that the problem could just be the ground of the motor, instead of the motor itself. Anyone knows something about this?Looks like this motor is hard to find outside of the official dealers. The 3 places I've called have motors for Matrix/Vibe 2008 and older, but nothing for 2009 and up. Could the motor of the 1st generation fit on the 2nd generation?BTW,, the GM dealer sells the motor $146.75 + $90 for the installation. Ouch...Thanks.
Re: (Eloi)
Posted: Thu Jan 06, 2011 6:32 am
by jake75
Who you gonna call - not ghostbusters, but eBay.Search 2009 Vibe wiper motor - example an almost new one for $35 & free shipping. I think this guy bought a new Vibe and is making money parting it out.
Re: (Eloi)
Posted: Thu Jan 06, 2011 10:27 am
by star_deceiver
Quote, originally posted by Eloi » Second, someone told me that the problem could just be the ground of the motor, instead of the motor itself. Anyone knows something about this?Loose connection! If you can get to it, the connector or one of the wires attached to it is probably loose. You might also want to check the connection of the stalk on/in the steering columb!
Posted: Fri Jan 20, 2012 3:52 am
by metaxa44
I have the same problem with my 2009 Vibe..Of course it is just out of warranty so have to deal with it...I tried to lube the shaft with no luck...I am thinking it could be the stalk connection...What was your problem ???Anton
Posted: Mon Nov 18, 2013 7:02 am
by Eloi
metaxa44 wrote:I have the same problem with my 2009 Vibe..Of course it is just out of warranty so have to deal with it...I tried to lube the shaft with no luck...I am thinking it could be the stalk connection...What was your problem ???Anton
Hi there, many months later, did you fix your problems? As for me, when I shook the wiper arms outside a bit, they'd always start, so I never bothered to replace anything. But since this weekend, they will stop at the highest speed, so now I have to do something. Check my new post here: viewtopic.php?f=17&t=42028" onclick="window.open(this.href);return false;
Posted: Mon Nov 18, 2013 9:35 am
by star_deceiver
If you shake them and they start you probably have debris in the internal gear mechanism of the wiper motor assembly. Probably something small that periodically lodges itself somewhere it shouldn't when you stop them. Or (if the electric motor has brushes) the brushes have corroded or seized in place and bumping them allows electrical contact.
If you have the mechanical ability (and tools), pull the motor assembly and take it apart. Clean all the gears and housing well, checking for damaged parts, re-lube and reassemble. Don't put lube on the brushes!
If you find something broken, it might be easier (and cheaper) to just buy a replacement motor assembly.
Posted: Mon Nov 18, 2013 9:40 am
by Eloi
star_deceiver wrote:If you shake them and they start you probably have debris in the internal gear mechanism of the wiper motor assembly. Probably something small that periodically lodges itself somewhere it shouldn't when you stop them. Or (if the electric motor has brushes) the brushes have corroded or seized in place and bumping them allows electrical contact.
Thanks. But is it sure it's the motor that is faulty, or it could be something like (like the controller)?
Posted: Mon Nov 18, 2013 8:10 pm
by star_deceiver
Pull one at a time, clean it and test.
Posted: Mon Nov 18, 2013 8:14 pm
by Eloi
star_deceiver wrote:Pull one at a time, clean it and test.
I'm no mechanic. Is it tough to do?
Posted: Mon Nov 18, 2013 9:11 pm
by star_deceiver
Since I no longer own the Vibe, I can't say how difficult it would be.... Or where some of the electronics would be located. Try the fuse block under the hood and under the dash for the wiper controller.
Posted: Tue Nov 19, 2013 7:57 am
by Eloi
Another question: does the Vibe 2009-2010 share the same wiper motor and controller with the Matrix 2009-2010? This could be good to know if I have to look for these parts.
Posted: Tue Nov 19, 2013 7:59 am
by kumquat
Eloi wrote:Another question: does the Vibe 2009-2010 share the same wiper motor and controller with the Matrix 2009-2010? This could be good to know if I have to look for these parts.
Yes.
Posted: Tue Nov 19, 2013 8:04 am
by Eloi
Yes.
Thanks.
