belt tensioner pulley!!!
Posted: Fri Dec 24, 2010 12:58 am
by skeletron
http://cgi.ebay.com/ebaymotors...%3AITbought that from ebay and had it installed and the belt is jumping ten times worse! could it be a bad part or is it the mechanics fault? there isn't very much tension on the belt when i push on it with my hand...need some help and ideas on this one because the mechanic says that the tensioner pulley is bad and it will cost another $60 in labor to reinstall a new one...is this part way cheaper than the dealers $255 price tag for a reason or do i just have a ****ty mechanic?
Re: belt tensioner pulley!!! (skeletron)
Posted: Fri Dec 24, 2010 1:15 am
by epcIII
Sorry I don't know, but maybe try a second opinion.
Posted: Fri Dec 24, 2010 1:32 am
by skeletron
that is what i am leaning towards...
Posted: Sat Dec 25, 2010 11:32 am
by star_deceiver
It almost sounds like it was installed wrong or backwards.
Re: belt tensioner pulley!!! (star_deceiver)
Posted: Sat Dec 25, 2010 1:58 pm
by jake75
So if you bought the part at the dealer and had it installed the bill would be about $350. What a rip.
Posted: Tue Dec 28, 2010 10:55 am
by skeletron
it ended up being the idler pulley...whoever owned it before installed a new one and never put the washer back in...the dealer were idiots! they didn't even know what size of belt to use haha i had the belt tensioner installed but it still made the same rattle noise with the belt jumping...
Re: (skeletron)
Posted: Tue Dec 28, 2010 11:04 am
by epcIII
At least it's fixed!
Posted: Tue Dec 28, 2010 11:05 am
by skeletron
yeah and it was a cheap fix!
Posted: Tue Dec 28, 2010 1:59 pm
by matrixjim
If replacing the pulley, once the belt is removed, do you need to remove the whole tensioner assy to replace the pulley, or is just a bolt holding the pulley on the frame that can be remove to replace the old pulley.
Posted: Tue Dec 28, 2010 2:00 pm
by matrixjim
whats the torque value for the tensioner pulley bolt?
