Restoring a Scratched Display?
VastOrangutan
Post by VastOrangutan »
Hi all,I feel like I've been posting like a madman trying to sort out all the little things involved with buying a used vehicle. I just bought an AWD Vibe with 115k and am trying to get everything the way I want it inside and out! (Auxiliary ipod adapter soon to be added).Anyway, the inside of the car is flawless, except for a severely scratched radio display. It is not so much small uniform scratches as it is a few larger nicks! It looks similar to a normal protective plastic film on a new screen that gets scratched and eventually needs to be removed to properly see the display. However, the marking is unfortunately on the display itself. Searched the forums and haven't found any info on restoring a display, if it's even possible.I've thought of clear nail polish or some sort of lacquer to smooth over the whole display, but I would like to maintain the low-glare of the original surface. Any ideas would be great!Thanks.
VastOrangutan. Yes, I have red hair.2003 Vibe AWD M&T PackageStock...For Now!
epcIII
Re: Restoring a Scratched Display? (VastOrangutan)
Post by epcIII »
As a descendant of redheads, I welcome you to Genvibe (even though it's not you first post)! Sorry, though, I'm no help on the display. But I think you would probably end up with a bigger mess if you try nail polish, etc..How deep are the scratches? Could you try a polishing compound with a dremel tool?Good luck!
dgekiere
Post by dgekiere »
THE STOCK RADIOS DISPLAY IS HARD TO SEE IN THE DAYLIGHT EVEN WHEN IT WAS NEW. THIS MAY WORK BUT MAY BE WAY OUT THEREhttp://www.autozone.com/autozo..._0_0_IT WORKS GREAT ON HEADLIGHTS AND ALSO GOT IT TO WORK ON A SCRATCHED COMPUTER DISK. ONLY USED THE WET SANDING DISK AND THE POLISHER. MIGHT BE WORTH A SHOT ESPECIALLY IF YOUR HEADLIGHTS ARE SCRATCHED TOO
2003 VIBE GT, CONVERTING TO RALLY CAR. http://forums.genvibe.com/zerothread?id=463112004 vibe gt magnaflow catback exhaust (bought totaled 9/06 with 1600 miles, fixed it and in love ever since2004 HONDA CBR1000RRASE Master certified mechanic
VastOrangutan
Re: Restoring a Scratched Display? (dgekiere)
Yes! I actually have some restoring compound I used to buff the haze off my headlights. I'll try it...it's just hard to guess how the surface will act since it's such a unique texture.
audiovibe
Post by audiovibe »
if the scratches are not that deep you could dry sand the display with some 2000-3000 grit sandpaper then use a polishing compound and polish by hand and get good results.
A Psycho Martyr
Re: (audiovibe)
Post by A Psycho Martyr »
I agree with audiovibe...try wetsanding with 2000grit with a LITTLE soap on it until you get an even haze, then polish the haze off with a buffing compound. Should come out nicely....ORIf you think you wanna fab something, you could get thin plexi or even a cd case cover and dremmel it to the shape/size you need, and try to replace the existing cover....just throwing ideas at ya
VastOrangutan
Re: (A Psycho Martyr)
Ended up using some emery cloth to get past the deep scratches, and then a restoring with the same wax/polish that I used to wetsand my headlights. Seemed to work! The Vibe is at peace once again.
epcIII
Re: (VastOrangutan)
Post by epcIII »
cptnsolo77
Post by cptnsolo77 »
I used plastX on my display. Didnt take out the deep scratches but helped clear it up a LOT !
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
