'06 Base Vibe: Can't find parking light wire (+)
Posted: Thu Nov 25, 2010 8:34 am
by Laserbeak43
Hello, I'm looking for the green (+) parking light wire in the harness in the driver side kick-panel that looks like this: http://www.bulldogsecurity.com...lldogI'm assuming that this wire isn't in my harness since it's not a model that came with power locks, windows, or an alarm.I've looked at bulldogsecurity:http://www.bulldogsecurity.com...lldogthe12volt:http://www.the12volt.com/insta...33385and code systems:Quote »BatteryBLACK(+)IGNITION SWITCH HARNESSIgnition 1BLACK/YELLOW(+)IGNITION SWITCH HARNESSStarter 1RED(+)IGNITION SWITCH HARNESSAll Door TriggerDomelight SuperRED/WHITE(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXLF LatchRED/WHITE(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXRF LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXLR LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXRR LatchRED(-)AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOXParking LightsGREEN/WHITE(-)AT VEHICLE LIGHT SWITCH HARNESSthe only wire i can find is the negative parking light wire in the switch harness.one interesting thing, is that the table from the12volt says that it's in the driver side REAR kick panel. where's that?any ideas?Thanks
Posted: Mon Nov 29, 2010 2:42 am
by Laserbeak43
it's in the wires under the side panel headed to the back of the car.
Re: '06 Base Vibe: Can't find parking light wire (Laserbeak43)
Posted: Thu Dec 02, 2010 1:16 pm
by audiovibe
This wire is in the drivers kick panel, for anyone else interested.
Re: '06 Base Vibe: Can't find parking light wire (audiovibe)
Posted: Fri Dec 03, 2010 7:39 am
by Laserbeak43
Quote, originally posted by audiovibe »This wire is in the drivers kick panel, for anyone else interested. If you'd like, I can show you a pic, there's no wire in the kick panel, unless by kick panel you mean the cover on the side of the doorway on the floor.
Posted: Fri Dec 03, 2010 1:33 pm
by audiovibe
The kick panel is the little panel directly in front of the door right next to the dead pedal, there should be 3 plugs under the panel the wire would be located in there.Here is what it looks like under the kick panel please ignore the wire taps they were from a previous remote start my wife had done when she bought the car.
