15" Winters for 2010 1.8L Vibe?
Posted: Tue Nov 23, 2010 1:43 am
by pantera623
Hi,was wondering if anyone has put a 15" wheel set on a 1.8L 2010 vibe.. Have been told mixed answers about whether or not it will clear the calipers. Any help is appreciated!
Re: 15" Winters for 2010 1.8L Vibe? (pantera623)
Posted: Tue Nov 23, 2010 2:38 am
by 09Vibe
Dealer (Toyota) told me that the 1.8's have smaller calipers then the 2.4L model so you can use a 15 fittment there, they probably have a multi fit rim at this point out there... but try and source a Corolla Rim anyway. Because of the caliper and hub offset issue with the 2.4L (2009 +) I understand you have to source a hubcentric OEM rim ( ie: Camry 16")Thats what I ended up doing and all is good. This guy helped me out actually:
http://www.joycitytires.com
Posted: Tue Nov 23, 2010 10:11 am
by star_deceiver
Never tried it... and the guys at the tire shop didn't know for sure for the 1.8. Easiest way is to get ahold of a 15" 5/100 rim and put it on.
Posted: Tue Nov 23, 2010 9:04 pm
by kowell
Olders discussions on the forum mention that the 1.8L model should have the same wheel setup as the old Vibe so you should be able to downsize to 15 inch without any problem by using wheels that could be equipped on the older Corolla, Matrix and Vibe.You should't have any problem but like it has been said, the best way to know is to try one wheel.The 2.4L model have bigger brakes that won't clear a 15 inch wheel. They also have a bigger bolt-pattern but this is unrelated to the current question.
