Wierd noise
Posted: Mon Nov 22, 2010 8:17 am
by 04chargedvibe
I've searched on the site for this and I haven't come up with an answer. This only happens when my engine is cold. When I start it up then put it in drive I hear a noise that sounds like a rock hitting a tin can. I've never heard it before and I'm not really sure where its coming from. Any ideas?
Re: Wierd noise (04chargedvibe)
Posted: Mon Nov 22, 2010 11:20 am
by epcIII
Reverse also?Mine made a similar noise and I had the belt tensioner pulley replaced and that fixed it.Good luck!
Posted: Tue Nov 23, 2010 3:31 am
by drunkenmaxx
most likely it's a heat shield rattling, very common
Re: (drunkenmaxx)
Posted: Tue Nov 23, 2010 3:43 am
by cptnsolo77
Thats what in thinking...heat sheild.
Re: (drunkenmaxx)
by 04chargedvibe
Ill have a look at the pulley and i would have checked the heat shield but i dont have one. i have a dc header on. im going to take a closer look today since im off work. ill let yall know if i find out anything.
Re: (04chargedvibe)
Posted: Wed Nov 24, 2010 3:47 am
by drunkenmaxx
on my 03 AWD, it was a heat shield over the transmission that was the culprit, surely you have one of those. (yes, i called you shirly)
Re: (drunkenmaxx)
Posted: Wed Nov 24, 2010 4:45 am
by keithvibe
Quote, originally posted by drunkenmaxx »(yes, i called you shirly)WoW drunkenmaxx... haven't seen you online in ages. WB
Re: (keithvibe)
Posted: Tue Nov 30, 2010 4:23 am
by drunkenmaxx
oddly enough, Leslie Nielson died shortly after i posted that
