timing chain question
Posted: Thu Nov 11, 2010 11:28 pm
by 69rustang
I am in the process of changing out the crank in '03 Vibe GT. Spun #2 rod bearing. I tried to get the timing marks to align, but they don't align when crank damper is at 0 degrees. The exhaust cam is off a few degrees when crank and intake cam are where they should be. the colored chain links are where they are supposed to be. Any ideas?
Re: timing chain question (69rustang)
Posted: Fri Nov 12, 2010 6:24 am
by keithvibe
You would be better off asking over at newcelica.org... more experienced engine builders there
Re: timing chain question (keithvibe)
Posted: Fri Nov 12, 2010 4:38 pm
by ou.grizzly
Quote, originally posted by keithvibe »You would be better off asking over at newcelica.org... more experienced engine builders thereJoatmon may be able to answer this question, hope he comes across it.
