How to: Remove Front Fascia (for 09)
Posted: Mon Oct 18, 2010 2:56 am
by vibedrivermatt
thread removed by vibedrivermatt. maybe will put back up a neater more edited version later.
Re: How to: Remove Front Fascia (vibedrivermatt)
Posted: Mon Oct 18, 2010 3:06 am
by keithvibe
Quote, originally posted by vibedrivermatt »and... what is this??two very small white and blue wires run to a small connector that goes to nowhere and is clipped to the car near the bottom of the rad. hmmmmmm? interesting. temp sensor...
Re: How to: Remove Front Fascia (keithvibe)
Posted: Mon Oct 18, 2010 3:08 am
by vibedrivermatt
oh really? I did not know this.
Posted: Fri Oct 22, 2010 4:25 am
by cq358
are you contemplating buying a set of oem fog?You can get turn signal switch from Rock auto around 90 bucks
Re: How to: Remove Front Fascia (cq358)
Posted: Fri Oct 22, 2010 8:42 am
by vibedrivermatt
Quote, originally posted by cq358 »are you contemplating buying a set of oem fog?You can get turn signal switch from Rock auto around 90 bucksyouknow actually I wanted to get some PIAA 410's. It would be cool if I could have them hooked up OEM style though. I just don't know how possible that is. Thanks for the information though!
Posted: Fri Oct 22, 2010 10:02 am
by cq358
Your write up is clear and full of pictures. keep up the good work.I am from Canada. Rockauto is the only place that their shipping included duty and custom broker fees. If any part you received is defective they will refund everything (incl shipping). I guess they uses FedEx Ground instead of UPS..
