What sensor is this
Posted: Wed Oct 13, 2010 3:17 pm
by fulltank
I just bought my 1st vibe, its a 2005, it was hit hard in the front and I am rebuilding it. There is a broken sensor at the lower front drivers side in the engine compartment. It looks like it was made of white plaster and there is a metal coiled wire inside, does any one know what this is? it would be greatly appreciated thanks. Right now it won't start I'm wondering if this is the reason.
Re: What sensor is this (fulltank)
Posted: Wed Oct 13, 2010 8:59 pm
by DressedInBlack
help us by posting a pic of said mystery item.
Posted: Wed Oct 13, 2010 11:02 pm
by 06pvibe
A wild guess as pictures would help, but could it be the air bag sensor that is supposed to live behind the bumper cover?
Posted: Wed Oct 13, 2010 11:11 pm
by scherry2
I'd make bets its a temp sensor for the outside temp display. the airbag sensor would be a small black plastic box with a ball bearing setting in a ballistics gel type substance.
Re: What sensor is this (scherry2)
Posted: Wed Oct 13, 2010 11:33 pm
by 06pvibe
Good point, scherry! I forgot about the outside temp sensor. My car doesn't have that one.
Posted: Wed Oct 13, 2010 11:36 pm
by ehoff121
Quote, originally posted by scherry2 »I'd make bets its a temp sensor for the outside temp displayI'm pretty sure the outside temp sensor is a small 3/8" thick black cylinder approx. 1 1/2" long, mounted behind the front bumper. http://www.rockauto.com/catalo...29732
Re: What sensor is this (ehoff121)
Posted: Thu Oct 14, 2010 1:21 am
by fulltank
I have attached a picture of the sensor I hope this worksThis sensor is in-cased in white cement or porcelain ?
Posted: Thu Oct 14, 2010 1:26 am
by Old Tele man
...that looks like: (A) an engine-block heater or (B) a big, heavy-duty resistor.
Re: (Old Tele man)
Posted: Thu Oct 14, 2010 3:29 am
by Sublimewind
Quote, originally posted by Old Tele man »...that looks like: (A) an engine-block heater or (B) a big, heavy-duty resistor.I would agree on the block heater, that's high temp/current wiring.. Although, wouldn't the block heater be connected to a 110 plug...?Is that part of the harness itself.. ?
Posted: Thu Oct 14, 2010 6:42 am
by fulltank
well its not connected to a 110 plug and it would have to be in the engine block to keep it warm,all the cement got broken away, it looks like an old style ballast resister
Re: (fulltank)
Posted: Thu Oct 14, 2010 7:51 am
by scherry2
when I fixed my front end I saw the sensor in question and the pointed temp sensor, thanks i learned something today.maybe a temp sensor for the fan?
Re: (fulltank)
Posted: Thu Oct 14, 2010 8:44 am
by 06pvibe
Quote, originally posted by fulltank »well its not connected to a 110 plug and it would have to be in the engine block to keep it warm,all the cement got broken away, it looks like an old style ballast resister I agree! A ballast resister (set?) of some kind.
Posted: Thu Oct 14, 2010 9:07 am
by fulltank
If someone can find a part number on theirsI could track down what its for
Posted: Fri Oct 15, 2010 1:19 am
by Sublimewind
I have the repair manual in my Sig, I'm sure you could find something in there too...
Re: (Sublimewind)
Posted: Fri Oct 15, 2010 2:00 am
by fulltank
That is great I will go through it when I have some time thanks so much
Re: (fulltank)
Posted: Fri Oct 15, 2010 10:10 am
by cq358
the factory block heater is at the back of the block..I think this is some kind of generic coolent/battery heater
Re: (cq358)
Posted: Sun Nov 07, 2010 12:17 pm
by fulltank
Well after a lot of search I found out what this sensor is for.As many of you suggested it is a resistor and its for the daytime running lights thanks for all your suggestions
