ScanGauge II and oil pressure and oil temp?
Posted: Sun Oct 10, 2010 10:08 am
by 21Rouge
I see on the ScanGauge website that with the latest software one has access to the XGauge features i.e.
http://www.scangauge.com/support/xgauge.shtmlFor those of you with this software can you tell me if your ScanGauge II is able to display the oil temperature in degrees F and oil pressure in PSI?Thanks for checking.
Posted: Mon Oct 11, 2010 10:06 am
by Water boy
Google is your friend.I've found much on some forums that I would have never found on my own where people have played around with the programing to get various readings.I've had 2 SG for 2+ years. Played a little with the programing on the Vibe when I first got it but never revisited. On my list to due before I die.
Posted: Tue Oct 12, 2010 3:51 am
by Old Tele man
...the ScanGauge-II can only display what information the computer passes along, and then only if the engine has the senor(s) to collect that information in the first place.
Re: (Water boy)
Posted: Tue Oct 12, 2010 4:10 am
by 21Rouge
Quote, originally posted by Water boy »Google is your friend.Of course but I am interested in the oil pressure and oil temperature for a Vibe. And as this is the forum for all things Vibe I thought it might be likely that someone here has used XGauge successfully in this regard.
Re: (Old Tele man)
Posted: Thu Oct 14, 2010 5:53 am
by 21Rouge
Quote, originally posted by Old Tele man »...the ScanGauge-II can only display what information the computer passes along, and then only if the engine has the senor(s) to collect that information in the first place.I understand. So I am wondering if any Vibe owners have been able to display oil temp and oil pressure using the XGauge software.
