Ground Wire
Posted: Wed Jun 18, 2003 9:49 am
by mwebb
I just hooked my system up today and I originally used a ground under the long compartment in the back. When i had everything hooked up it did not work, so I tested the connections and the ground somehow had power. So now I have it hooked up to the tie down strap holders.Where are other Vibers grounding there systems at? I like all wires to be hidden, any sugestions?thanks
Re: Ground Wire (mwebb)
Posted: Wed Jun 18, 2003 11:45 am
Can't you run it through the firewall into the engine bay?
Re: Ground Wire (ragingfish)
Posted: Wed Jun 18, 2003 9:56 pm
by Sub-Vibe-R
I grounded my subwoofer by using the bolt who hold the plastic area in the back.
Posted: Wed Jun 18, 2003 10:07 pm
by pissedoffgokart
I used one of the bolts under the E-brake lever...
Posted: Thu Jun 19, 2003 9:39 am
by mwebb
quote:Can't you run it through the firewall into the engine bay?Yeah that is possible but I was looking for a ground that was closer to the sub box on all my other cars my ground wire was only 18 inches or less.I will prolly just use the ground I have now...Unless I get around to making my custom box..thanks for the input everyone.
Posted: Fri Jun 20, 2003 3:11 am
quote:Where are other Vibers grounding there systems at? I like all wires to be hidden, any sugestions?thanks In the Matrix subwoofer install PDF at the link that jgvibe posted on thread
http://forums.genvibe.com/zeropost?cmd=reply&id=49169 , Toyota says to use one of the rear seat mounting bolts for a ground, accessible by slightly folding forward the rear seatback a little.
