				What psi should I keep winter 16" tires at?
				Posted: Wed Oct 06, 2010 9:42 am
				by vibenvy
				I'm still a ways off from putting our steelies on for the winter, but I got to thinking about this the other day and figured I'd post about it now before I forget.So, both our '09 GTs obviously have the stock 18" wheels and tires. The sticker on the driver's side door jamb recommends 32 psi for the 215/45/18 tires, so that's what I keep them at. Last winter I kept our 205/55/16 tires at 32 psi as well, but I got to thinking, should I actually be keeping them at 35 psi which I have read on here is the recommended psi for the stock 16" tires on the '09 Bases?Any information and/or opinions is greatly appreciated. Thanks in advance.
				Re: What psi should I keep winter 16" tires at? (J_TO_ENVY)
				Posted: Wed Oct 06, 2010 10:27 am
				by star_deceiver
				My door jam says 32psi for the stock tires.
				Re: What psi should I keep winter 16" tires at? (star_deceiver)
				Posted: Wed Oct 06, 2010 10:44 am
				by Kamikaze
				between 32 and 35 psi. If you are seeing more wear on the center of the tire than the sides, then I would suggest a lower psi (32) if there is more wear on the outer edges than the center I would suggest a little higher psi (35-37).If they are wearing even then I would keep them around the 32-35 mark.
				Re: What psi should I keep winter 16" tires at? (Kamikaze)
				Posted: Wed Oct 06, 2010 10:47 am
				by star_deceiver
				But I ran my Firestone winterforce at 40psi (max 44psi) all last winter with no problems!!!
				Posted: Thu Oct 07, 2010 10:47 am
				by vibenvy
				Okay, I guess I'll keep them at 32 than. Thanks guys!
				Posted: Thu Oct 07, 2010 12:27 pm
				by jake75
				Quote, originally posted by J_TO_ENVY »Okay, I guess I'll keep them at 32 than. Thanks guys!Seems to me that 34 psi is the recommended psi for the 2009.
				Re: What psi should I keep winter 16" tires at? (jake75)
				Posted: Thu Oct 07, 2010 12:31 pm
				by jake75
				Quote, originally posted by jake75 »Seems to me that 34 psi is the recommended psi for the 2009.My bad - just checked.  It does say 32 psi.  I still favor a little over rather than a little under.
				Posted: Mon Oct 11, 2010 3:35 am
				by Sublimewind
				Quote, originally posted by star_deceiver »But I ran my Firestone winterforce at 40psi (max 44psi) all last winter with no problems!!!Jus cause you did it and it worked, doesn't mean it's recommended.. lol..
