installed sub amp, radio thermally shuts off
bassplayaz06
Post by bassplayaz06 »
i installed a 460 watt Dual amp and 2 premier subs in my car today, ran the input off the passenger rear speaker. the radio will play for about a minute then just cut off. my display is dead so i cant see if it says anything. im thinking its drawing too much current and shutting off. any advice?
2003 Vibe GT, 1.8L, 6 speed Manual Lava Red 2 tone18" sport edition rimsCosmo CAIMy Garage http://forums.genvibe.com/zerothread?id=42483
audiovibe
Post by audiovibe »
Did you use a converter or splice the RCAs into the rear channels? After the radio shuts down does it re-power by its self? Where is your remote wire tied in at? Where did you pull power for the amplifiers 12V input? Do you have the factory moon and tunes package? If I placed a guess in left field I would say you have a short somewhere. With that said, make sure none of the connections are shorting out. I really don't think you are pulling enough current to drop the radio just by adding an amplifier. If your battery and alternator are weak I could see the added current being an issue, but then you would also have other issues.
Sublimewind
Post by Sublimewind »
Does the radio cut out, and the sub keeps playing, or is the sub amp cutting out too...?? As Audio said, how are you connected.. I would trust a Dual amp speaker level input section to save my life.. Just an opinion thought..
bassplayaz06
Re: (audiovibe)
i have the RCA's spliced into the rear passenger speaker, the remote just connected dirrectly from the remote spot to the power input (temporary), the amp's connected dirrectly to the battery, and both the radio and the subs cut off. after a couple minutes, the radio comes back on if the subs are off and its at a low volume.
audiovibe
Post by audiovibe »
Try disconnecting the RCAs to see if the issue is still present. Did you use a line level converter to adjust your voltage?
bassplayaz06
Re: (audiovibe)
i haven't tried those yet. my friend that i bought the amp from said it might be a loose ground.
DrunkenMonster
Post by DrunkenMonster »
If you keep the volume down, does it still shut off?
2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote StartK&N Panel Air Filter, Removed Silencer, TB Coolant Bypass1998 Jeep Cherokee UKFlowmaster Super 44Cobra 25 LTD CB 2 JL Audio 10W0's / TMA 500
bassplayaz06
Re: (DrunkenMonster)
yes, it takes a bit longer, but it still does. my friend said it was a loose ground. im gonna try that later.
Sublimewind
it's not a lose ground, it's that you spliced the RCA (low level) into the speaker wires (high level) and you are over-driving everything.. Quote »i have the RCA's spliced into the rear passenger speaker,you need a LOC (Line Output Converter)
audiovibe
Re: (Sublimewind)
Post by audiovibe »
Quote, originally posted by Sublimewind »it's not a lose ground, it's that you spliced the RCA (low level) into the speaker wires (high level) and you are over-driving everything.. you need a LOC (Line Output Converter) That's the same direction I was heading
bassplayaz06
Re: (Sublimewind)
oh ok. so i have to go get it from walmart and rewire the harness part tomorrow then.
