Harness Part Number, Need Help
Posted: Sat Sep 25, 2010 5:55 pm
by petervivian
Anyone knows the part number of the following harness please?This is a 10-pin harness, and there are quite a few of them in our vibes, though they may be in different colors. In my car, the male one of this harness is broken. It is located at rear of the car (driver side) and goes to the lift gate. The Matrix repair and wiring manual does have a lot of information on the other connectors, but the part number of this harness is not mentioned. If anyone knows where to get this harness, please let me know. Thanks.
Re: Harness Part Number, Need Help (petervivian)
Posted: Sat Sep 25, 2010 6:02 pm
by petervivian
It is a 10-pin harness.
Posted: Sat Sep 25, 2010 7:19 pm
by 808 Vibes
Let me try to summon the parts master for you... hold on...EDIT: bat signal sent, he should be here shortly.
Re: Harness Part Number, Need Help (HawaiiPontiacLover)
Posted: Sun Sep 26, 2010 2:58 am
by petervivian
Thanks. I once thought of cut the harness and solder the eight wires, but instead I believe I can do a neat job with the help from you guys
Posted: Sun Sep 26, 2010 4:45 am
by 808 Vibes
Paging Tnpartsguy...
Posted: Sun Sep 26, 2010 11:02 am
by 808 Vibes
I've sent up another bat signal...where is our caped crusader?
Posted: Sun Sep 26, 2010 2:22 pm
by petervivian
Some members from MO provided a solution: I use the apple steel pin to pry the plastic clips inside the harness, then I am able to remove the wires from the harness. So if I can not find a new one, at lease I can head down to the junkyard and cut an used one, then remove its wires one by one.
Posted: Mon Sep 27, 2010 6:19 am
by 808 Vibes
BUMP so he can find this!
