Oil mixed into the fuel, car won't start
Posted: Sun Aug 29, 2010 12:25 am
by Maury Markowitz
11 litres (about 4 US gallons) of some sort of oil/gas mix were put into the tank of a 2008 Vibe. The car ran for a short time, but will no longer start.My guess is a plugged fuel filter? Any other things to check?Maury
Re: Oil mixed into the fuel, car won't start (Maury Markowitz)
Posted: Sun Aug 29, 2010 12:48 am
by star_deceiver
Fouled spark plugs, clogged injectors.Remove a fuel line from the engine area and place the end in a bucket. Turn the key to ON without trying to start the car and wait for the fuel pump to pump all the gas from the tank. Change the fuel filter after it's done, reattach the line, fill with gas w/ injector cleaner (like seafoam) clean the plugs and cross your fingers!!!
Posted: Sun Aug 29, 2010 1:09 am
by djkeev
Yep, drain clean and hopefully run.Consider yourself lucky. IF you had a diesel and someone put gas in it your problems would be far more severe and hard to fix than a little oil in gasoline ever is!!Count the little blessings along the way.Dave
Re: Oil mixed into the fuel, car won't start (djkeev)
Posted: Sun Aug 29, 2010 1:56 am
by jake75
So how did that happen?
Posted: Sun Aug 29, 2010 10:53 am
by SlammedNiss
Lemme guess, you grabbed the wrong gas can at home and grabbed the one for the weed whacker?
Re: (SlammedNiss)
Posted: Sun Aug 29, 2010 1:17 pm
by ou.grizzly
Quote, originally posted by SlammedNiss »Lemme guess, you grabbed the wrong gas can at home and grabbed the one for the weed whacker?If this did happen (2 cycle mix), it could of been avoided by folks using/labeling the containers properly. Sharpie Marker is your friend!
Re: Oil mixed into the fuel, car won't start (star_deceiver)
Posted: Sun Aug 29, 2010 8:31 pm
by Maury Markowitz
I was going to do this test, but couldn't find which line to disconnect. The fuel distribution appears to come in on the right side of the engine via an insulated copper (?) pipe, right? Then it's connected to a short bit of flex, into some sort of controller (is that a throttle body?) and then back out into the distribution system on the engine. Which one is a good one to remove?Maury
Posted: Mon Aug 30, 2010 10:38 am
by star_deceiver
Can you disconnect the line that goes directly into the fuel rail?
