key blanks
Posted: Sat Aug 21, 2010 3:32 am
by kartrac3r
where is the most reputable to get a key blank and keyfob without paying out the nose?
Re: key blanks (kartrac3r)
Posted: Sat Aug 21, 2010 4:31 am
by jake75
I once bought an extra FOB for my 2003 on eBay.Seems to me it was about $20 including shipping.If I could find it I'd offer it for sale.
Posted: Sat Aug 21, 2010 4:53 am
by ou.grizzly
Do you need a key fob for a 2003-2008 Vibe or a 2009+ Vibe?
Re: key blanks (ou.grizzly)
Posted: Sat Aug 21, 2010 9:56 am
by lovemyraffe
I have an extra key fob I'd be willing to part with.
Posted: Tue Aug 24, 2010 9:57 pm
by kartrac3r
its for an 03-08. Another question, are they easy to program?
Re: (kartrac3r)
Posted: Wed Aug 25, 2010 11:42 am
by SlammedNiss
Quote, originally posted by kartrac3r »are they easy to program?From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.
Posted: Wed Aug 25, 2010 2:22 pm
by A Psycho Martyr
Ummmm.... key FOB?
Re: key blanks (A Psycho Martyr)
Posted: Wed Aug 25, 2010 3:40 pm
by ou.grizzly
Quote, originally posted by A Psycho Martyr »Ummmm.... key FOB?
Posted: Wed Aug 25, 2010 7:09 pm
by A Psycho Martyr
Oh ok. Thanks grizzly
Re: (SlammedNiss)
Posted: Thu Aug 26, 2010 3:02 am
by kartrac3r
From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.sounds like a more complicated version of the chinese fire drill
Re: (kartrac3r)
Posted: Thu Aug 26, 2010 3:23 am
by lovemyraffe
Quote, originally posted by kartrac3r »sounds like a more complicated version of the chinese fire drillYou feel like a complete idiot while sitting in your driveway with your neighbors watching you do this, but it does work.
Re: (lovemyraffe)
Posted: Thu Aug 26, 2010 7:14 am
by jake75
You forgot the "put your left foot in, pull your left foot out . . . "
