Fog lights came in today!
Posted: Fri Aug 13, 2010 9:46 am
by Pudntain
Got the grilles from gmpartsdirect, part numbers are on a thread here somewhere. The trick is where to get the lights. GM wanted 90+ each without wiring. Did some research, there are a lot, a lot of toyotas that use the same light. Found a set with wiring for a 08 camry for $52. The grilles and lights are in, but run out of daylight before I could start wiring. Will wire them to a switch on the panel to the left of the steering column. Will tie them in to the parking lights so they will only function when parking lights are on, but also will be able to turn them off during the day. Only got pick of one side before it got dark, will post before and after.
Re: Fog lights came in today! (Pudntain)
Posted: Fri Aug 13, 2010 9:48 am
by Pudntain
Here is the after, toyota lights fit perfect. Will post after i get the wire done, let you know what kind of a nightmare that is.
Posted: Fri Aug 13, 2010 11:16 am
by vibenvy
Looks great ! You're definitely off to a great start with your Vibe! You should start a Garage thread for it so we can keep tabs on your progress .
by morbay
That looks great, I wouldn't mind doing that to mine. Where did you pick up the set for $52?
Posted: Fri Aug 13, 2010 11:20 am
by ponta2147
Hooray for adding fog lights!
Posted: Fri Aug 13, 2010 11:33 am
Quote, originally posted by Pudntain »Here is the after, toyota lights fit perfect. Will post after i get the wire done, let you know what kind of a nightmare that is. Nice job Now it's time to tackle a few more SERIOUS mods !!! This site has a way of doing that to us members. I want to dig into my next mod Sooooo bad but have to wait till the fall when I know I'll have the time to follow through & finish Then there will be Santa's workshop where I know I'll be EXTREMELY busy
Re: (ponta2147)
Posted: Fri Aug 13, 2010 12:07 pm
by Pudntain
got the lights on ebay, free shipping too. they have more.....Sabersport ebay store 07-09 camry. actually comes with the camry grills, wiring and dash switch.
Re: (Pudntain)
Posted: Fri Aug 13, 2010 3:49 pm
by star_deceiver
$52!!! Nice deal!!!
Posted: Sat Aug 14, 2010 2:53 pm
by Kincaid
Pudntain - how did you access the old grille blanks? Do you have to drop the cover that runs below the bumper cover?
Re: (Kincaid)
Posted: Sun Aug 15, 2010 12:42 am
by star_deceiver
Quote, originally posted by Kincaid » Do you have to drop the cover that runs below the bumper cover?I never did. Unless your model of Vibe had extra plastic down there.You can reach up from under the bumper and push the tabs in and push forward and it will begin to pop out. There are 5 I believe, havn't had mine off in a while but I recall them being stubborn... The wiring is neatly tied up right there as well.
Re: (star_deceiver)
Posted: Sun Aug 15, 2010 9:40 am
by Pudntain
There is a cover, three bolt/screws, drops down from the front, I think it goes up and is part of the wheel well cover too. Then reach in and release the five tabs.
Re: (Pudntain)
Posted: Mon Aug 16, 2010 10:22 am
by vibedrivermatt
cool! You know you probably shouldn't need that wiring though. Vibes come pre wired for the fogs so you should just be able to plug them in. Then you just gotta figure out how to hook up that dash switch. Theres a thread about it on here I think the Speedeng guy did it
Posted: Tue Aug 17, 2010 2:02 pm
by Kincaid
Yes he did - I believe he was the first.
