Spark plugs replaced
Posted: Fri Aug 13, 2010 5:33 am
by 21Rouge
OEM plugs removed today from our 05 Vibe with 59k miles.Although they look fine I still replaced them .
Re: Spark plugs replaced (21Rouge)
Posted: Fri Aug 13, 2010 5:39 am
by BlueCrush
They do look good. You probably could have gone another 59K on them.
Re: Spark plugs replaced (BlueCrush)
Posted: Fri Aug 13, 2010 5:42 am
by 21Rouge
You might be right Blue Crush. But I guess I take some consolation in that it will be the last time I replace the plugs in this vehicle.
Posted: Fri Aug 13, 2010 7:58 am
by Old Tele man
...unless you're running trashy gasoline, iridium-tip plugs should last 100K-miles no problem.
Re: (Old Tele man)
Posted: Sun Aug 15, 2010 2:37 am
by cutehumor
I'm not sure how the 2.4 Liter treats spark plugs, but if they are irridium. I'm gonna run them to 100k as well.
Posted: Sun Aug 15, 2010 3:33 am
by cptnsolo77
They do look pretty good still. Any difference in how the car idles / drives?
Re: (cptnsolo77)
Posted: Tue Oct 05, 2010 10:40 am
by Digger
I have 95,000 on mine and will change at 100,000. I think the book said to run them 120,000 before they need changed.
Posted: Tue Oct 05, 2010 10:49 pm
by Bedlam
Inexpensive preventative maintenance is a good practice. Nothing wrong with changing a set of plugs out for piece of mind on a 60k motor. Sure, you got some life left in em but the swap will give you years of not having to worry about them.i think i am getting close to changing mine. I bought this one used as a 2003 and the original plugs are still in it. It's such an easy and cheap job i don't see any trouble in doing them early since there are only 4 of them and they are easy to get to. It's only bad when i have to buy 16 for my other ride....
