Daytime running lights on all the time?
Posted: Mon Aug 09, 2010 9:57 am
by nittanydoug
I have a 2005. Should my DRL's be on whenever the car is running? Even when not in gear? I went to a drive-in over the weekend and I had to have the windows open and car off (no a/c and it was humid) so I didn't have my headlights on.
Re: Daytime running lights on all the time? (nittanydoug)
Posted: Mon Aug 09, 2010 10:05 am
by vibenvy
Yes. The DRLs will be on whenever the car is running, whether it's in gear or not. If you're parked (like at the Drive-In), you could engage the e-brake and that will turn the DRLs off even though the car is running.
Posted: Mon Aug 09, 2010 10:15 am
by nittanydoug
That makes sense. The thought never crossed my mind to pull the e-brake. I swear my wife's saturn vue the drl's aren't on when it's in park. Then again I don't know that I pay that much attention.
Re: (nittanydoug)
Posted: Mon Aug 09, 2010 10:29 am
by vibenvy
They very well could stay off until the Vue is put in gear. Every car is different I suppose.But yes, for your Vibe, just engage the e-brake. I remember when I did my first oil change on my '09. I had the e-brake engaged since the car was up on the ramps. When I started it to back it off the ramps I thought something was wrong because the DRLs weren't on. Then I realized it was because the e-brake was engaged . I eventually ended up just disabling the DRLs/AHLs on my '09 so now I have full control over all the lights all the time which is the greatest thing ever. That could be another possible solution for you as well, if you're so inclined. It's very easy to do.
Posted: Mon Aug 09, 2010 10:41 am
by keithvibe
for situations like that pull up your emergency brake. it should disable them, which i see j has already mentioned
Re: (nittanydoug)
Posted: Mon Aug 09, 2010 11:47 am
by 09vGT
I guess GM other cars DRL's don't come on until put into gear.. my mom Cadillac CTS's won't come on until the The car is put into some gear besides park..
Posted: Tue Aug 10, 2010 1:08 am
by kostby
Actually, the e-brake has to be engaged with the ignition completely off. Then you can start/run the car and the lights remain off until the e-brake is released.The '05 manual is here --> http://www.genvibe.com/images/...e.pdfThis thread I just posted details the '03 (and up) DRL operation --> http://forums.genvibe.com/zerothread?id=42131
Posted: Tue Aug 10, 2010 2:09 am
by nittanydoug
I didnt' try that. I did notice that they didn't go off when I pulled the e-brake in the parking lot at lunch. That's the hazard of buying a used car with no owner's manual.
Re: (nittanydoug)
Posted: Tue Aug 10, 2010 8:32 am
by vibenvy
Quote, originally posted by nittanydoug »That's the hazard of buying a used car with no owner's manual.There's a plethora of owner's manuals on eBay .
Posted: Sun May 22, 2011 1:37 am
by gvon79
HELP! I'm going to the drive-in theater tonight and I can't get my 2009 Vibe to start without the DRL coming on. Even with the parking break applied, the DRL still comes on?!?
Posted: Sun May 22, 2011 12:57 pm
by j42.snyder
You're having the AHL's come on when it's dark - which can't be manually over-ridden on a '09 without modification.I'm sure there's info on this in the How-to section, as I did this on my '09 last year. I added a switch so that I can retain "normal" automatic operation most of the time, but switch it back to full manual when I want.If you aren't worried about DRL's working, and don't care for the AHL's either, then you could just snip one wire to disable both.Unfortunately this response is a little late to help with the drive-in situation tonight though...John
Posted: Sun May 22, 2011 2:41 pm
by gvon79
Thanks John, I ended up snipping the wire to disable both but I plan on adding an on/off switch in the near future.
