Blue or red Loctite on flywheel bolts?
mntn-biker
Post by mntn-biker »
I bought a set of ARP flywheel bolts and they do not have any thread locker on them. Should I use the blue or red Loctite on the new bolts when I install the flywheel.Thanks - Mike
2003 base model
Re: Blue or red Loctite on flywheel bolts? (mntn-biker)
I have red 272 that I use on anything I forsee never needing to come apart (mainly because that's what's at hand)
mntn-biker
Re: Blue or red Loctite on flywheel bolts? (star_deceiver)
Quote, originally posted by star_deceiver »I have red 272 that I use on anything I forsee never needing to come apart (mainly because that's what's at hand)The shop that resurfaced my flywheel said to use the red on the flywheel bolts and the clutch cover bolts. He said anything that you won't be (or shouldn't be) taking apart for a very long time and that is prone to the high rpm's and/or vibration I should use the red.
2003 base model
Vibenator
Post by Vibenator »
They'll both work well. I used the same bolts on the flywheel of my '03 GT. I contacted ARP and they said that either would work well provided that the bolts were torqued down to around 70 ft. lbs. I was also infomred that 30w motor oil can also be used with aournd 50lbs. of torque. The ARP bolts are specially hardened aircarft grade steel. They're much stronger than the stock bolts, so they can be tightened more than the 35 ft. lbs. that Pontiac (Toyota) recommends.
2002 Chrysler T&C Minivan, 2003 Pontiac Vibe, 2004 Chrysler Crossfire
